Samsung Galaxy Buds FE
Contents
Unleash the Power of Sound with Galaxy Buds FE
In today’s fast-paced world, having a reliable pair of earbuds is essential. Whether you’re commuting, working out, or just relaxing at home, you want earbuds that offer exceptional sound quality and convenience. Samsung’s Galaxy Buds FE (Fan Edition) fits the bill perfectly, combining sleek design with cutting-edge technology. Let’s dive into the details to discover what makes these earbuds stand out.
Design: Compact and Comfortable
The Galaxy Buds FE are designed with both style and comfort in mind. The earbuds themselves measure 17.1 x 19.2 x 22.2mm and weigh a mere 5.6g each, ensuring a snug and comfortable fit. The charging case, measuring 50.0 x 27.7 x 50.0mm and weighing 40.0g, is compact and easy to carry in your pocket or bag.
Audio Excellence: A 1-Way Speaker
With a 1-way speaker system, the Galaxy Buds FE deliver clear and immersive sound quality. Whether you’re listening to your favorite music, taking calls, or enjoying podcasts, these earbuds provide an exceptional audio experience.
Crystal Clear Calls: Triple Microphone Setup
The Galaxy Buds FE are equipped with three microphones—two outer and one inner microphone. This advanced setup ensures that your voice is crystal clear during calls, even in noisy environments.
Battery Life: All-Day Entertainment
Battery life is a crucial factor when choosing earbuds, and the Galaxy Buds FE don’t disappoint. The earbuds themselves boast a 60mAh (typical) capacity, while the charging case packs a 479mAh (typical) battery. With ANC (Active Noise Cancellation) on, you can enjoy up to 6 hours of playtime with the earbuds, and the case extends that to a total of up to 21 hours. With ANC off, you get up to 8.5 hours of playtime with the earbuds and up to 30 hours in total. Plus, you can even enjoy up to 3.5 hours of talk time with ANC on (up to 4 hours with ANC off), and the case extends it to up to 13 hours with ANC on (up to 14 hours with ANC off). These earbuds are built to keep up with your daily activities without needing constant recharging.
Seamless Connectivity: Bluetooth 5.2 and Auto Switch
The Galaxy Buds FE feature Bluetooth® 5.2 connectivity for a stable and fast connection to your device. They also come with Auto Switch functionality, allowing you to seamlessly switch between your paired devices. Whether you’re listening to music on your smartphone or taking a video call on your tablet, these earbuds make it effortless.
High-Quality Codecs: Scalable, AAC, SBC
The Galaxy Buds FE support multiple audio codecs, including Scalable (Samsung Proprietary), AAC, and SBC, ensuring that you get the best possible audio quality, no matter what device you’re using.
Smart Sensors and Compatibility
These earbuds are equipped with proximity, hall, and touch sensors, allowing for intuitive touch controls and smart wear detection. They are compatible with Android 8.0 or higher devices with more than 1.5GB of RAM.
