Vertical Docking Stations for SATA Hard Drives
Sharkoon Vertical Docking Single/Duo USB3.0: lockable, external docking stations for one or two 3.5″ SATA Hard Drives | MSRP starting at 34.90 euros
Sharkoon presents two external hard drive docking stations for the USB3.0 interface, in which unobstructed SATA hard drives can be quickly and without effort connected to a computer or notebook. The two Sharkoon Vertical Docking USB3.0 stations, with a choice of either one or two fast-swap bays for SATA hard drives in 3.5 inch format, are equipped internally with a SATA II interface and externally with a USB3.0 SuperSpeed interface.
The disks are easily inserted upright lengthwise into the hard drive bay. A lockable front flap secures the drives against unwanted access while a rear fan helps prevent unwanted heat. The Sharkoon Vertical Docking Single USB3.0 Station with its hard drive bay and 40 mm fan measures 212 x 44 x 129 mm (L x W x H) and weighs 650 g. The Sharkoon Vertical Docking Duo USB3.0 Station with its two individually lockable hard drive bays and 50 mm fan measures 222 x 83 x 134 mm (L x W x H) and weighs 860 g.
The matte black, rounded plastic case features an on/off switch, red and blue illuminating LEDs indicating power and data access, and supports the operating systems Windows XP, Windows Vista and Windows 7 (32 bit and 64 bit). Enclosed with both models are a power supply, a USB3.0 cable, two keys and a brief manual.
End customers will find the Sharkoon Vertical Docking Stationen available in authorized retailers.
Price:
Sharkoon Vertical Docking Single USB3.0 MSRP 34.90 euros
Sharkoon Vertical Docking Duo USB3.0 MSRP 59.90 euros
