Silicon Power Takes You to New Visual Heights
~ The New Full HD Camera / Camcorder Memory Card
May 4, 2010, Taipei, Taiwan ~ Leading flash memory manufacturer Silicon Power today announced that Full HD Camera / Camcorder Memory Card dedicated for HD digital camera / camcorder use. Silicon Power’s perseverance shows with its high quality built and fashionable looks. Specially developed for Full HD camera / camcorder enthusiasts, the memory card is wrapped in flaming red and gold coloring to show off its passion for data storage. With the release of Full HD Camera / Camcorder Memory Card, Silicon Power hopes to win over the hearts of camera / camcorder enthusiasts in their quest to capture every precious moment!
Silicon Power’s Full HD Camera / Camcorder Memory Card is compatible with SDHC Class 6 specifications. Featuring Content Protection for Recordable Media (CPRM) and Error Correcting Code (ECC), enthusiasts can be rest assured that their data is well protected when recording HD format contents. This time around on the sticker of the memory card, there is space for users to place their own labeling words so enthusiasts can clearly identify the data stored on the card without a computer!
Silicon Power’s Full HD Camera / Camcorder Memory Card is available in 4 different capacities including 4GB, 8GB, 16GB and 32GB.
? 4 GB 8 GB 16 GB 32 GB
Video HD (Hi-def movie recording MPEG-4. H.264)
Fine mode (13Mbps/CBR) 40 min. 80 min. 160 min. 320 min.
Normal mode (9Mbps/VBR) 60 min. 120 min. 240 min. 480 min.
Economy mode (6Mbps/VBR) 90 min. 180 min. 360 min. 720 min.
* All numbers are approximate. Actual storage will depend on size of data and compression used.
Features?
?Specially designed for high end video cameras and camcorders, optimized for full HD 1080p video recording.
?Compatible with SDHC host devices.
?In compliant with SDHC Class 6.
?Space for labeling recorded video content.
?Supports Content Protection for Recordable Media (CPRM).
?Security level complies with Secure Digital Music Initiative (SDMI).
?Built-in Error Correcting Code (ECC) to detect and correct transfer errors.
?Mechanical write-protection switch.
?In compliant with RoHS requirement.
Specifications?
– Dimension?24mm x 32mm x 2.1mm
– Weight?2g
– Compatible with SD 2.0 specifications
– Durability test?Plug and pull at least 10,000 times
– Operating voltage?2.7V ~ 3.6V
– Operating temperature: -25?~85?
– Storage temperature: -40?~85?
– Humidity tolerance?8% to 95%
– Lifetime warranty
