The video highlights the variation in Speedtest results when testing the speedtest app against servers located in Singapore and Malaysia. Most servers in Singapore appear to be limited to 1 Gbps, resulting in generally lower speedtest readings. If you opt for automatic server selection, you might mistakenly think that the wired fibre broadband is way slower than its actual speed of 2.5 Gbps. e.g. less than 1 Gbps.
