Considered to be the fifth generation of Sony’s next-generation successor – flagship mobile phone Xperia 1 V. This new model has a borderless design and a hidden front camera.
According to foreign media Sumahodigest, it is said that Xperia 1 V, the fifth-generation new flagship mobile phone, will be equipped with Qualcomm Snapdragon S8 Gen 2 processor based on TSMC’s four-nanometer process technology, which is expected to be launched by Sony Mobile in the first half of next year. It is estimated that it is likely to be officially launched in May 2023 according to previous model launch roadmap. It might make an appearance in May 2023 or earlier.
According to ray traced photos leaked on the net, the Xperia 1 V fifth-generation flagship will have a refresh design. It will still come with a 21:9 ratio consistent with previous generations, and maintains the signature features of no bangs and no digging holes, It is almost bezeless.
The front selfie camera, is now embedded under the screen. The screen size remains the same as the previous generation’s 6.5-inch 4K HDR OLED, and it also has a high refresh rate of 120Hz.
The main camera also maintains the usual vertical arrangement design, but it is reported that the Xperia 1 V fifth-generation flagship new machine is likely to be upgraded from “three-lens” to “four-lens”, and adopts a “one long and one short” double-arranged shape, that is, A new set of lenses is added to the right side of the rear three-lens camera module, but the detailed sensor specifications are not known. The main camera is may be upgraded to a 48 megapixel and it might use a larger sensor than before.’
