Thermaltake Mobile – LUXA2, a market leader in power, audio and holder solutions, takes on the year of wireless charging with new and exciting Wireless Power Consortium (WPC) solutions – TX-P2 10,000mAh Wireless Charging Power Bank , TX-P1 5000mAh Wireless Charging Power Bank, TX-100 Ultra Slim Wireless Charging Pad, and TX200 Dual Wireless Charging Station – designed for a cable-free home, work and travel charging environment, certified for overall reliability, safety and with full two-year warranty!
Qi, developed by the WPC is the most widely adopted wireless charging standard in the market and is the standard for all LUXA2 wireless charging products. As a market leader, the Qi wireless standard can be found in many industry sectors such as hospitality, automotive and recently, home furnishing. No longer is it camped in the corner of consumer electronics and the above is a testimony to its continual and expanding development.
Since February last year, in anticipation of this boom in wireless charging, LUXA2 has already released a host of wireless charging power banks : TX-P1 5000mAh Wireless Charging Power Bank and TX-P2 10,000mAh Wireless Charging Power Bank, also wireless charging pads TX-100 Ultra Slim Wireless Charging Pad and TX200 Dual Wireless Charging Station with full two-year warranty, to create a total wireless charging solution that combines wireless charging with power bank, and separate wireless charging stations for the modern gent and ladies.
TX-P1 5,000mAh Wireless Charging Power Bank
The TX-P1 is a 5000mAh portable wireless charging power bank, capable of charging your Qi wireless compatible device several times over. The TX-P1 also supports wired charging in the form of a single 5V1A output port for multiple charging of devices for a cable-free charging environment.
Key Features of the TX-P1 5,000mAh Wireless Charging Power Bank at a Glance:
Grade A 5,000mAh lithium-polymer battery cell
Dual function charging pad and power bank
5V1A USB output port
Supports simultaneous wired and wireless charging
Easy power on/off with 4 LED power charging indicators
Includes band of portability for secure wireless charging on the move
Qi compatible
TX-P1 5,000mAh Wireless Charging Power Bank suggested price: USD 59.99
More information on the TX-P1 5,000mAh Wireless Charging Power Bank is available online: http://www.luxa2.com/product.aspx?s=114
T
Packs double the capacity of the highly successful TX-P1, and cramps enough juice to charge your iPhone 6 / 6 Plus and Samsung S5 several times over without compromising portability. The TX-P2 works with all Qi compatible devices and possesses a lightning fast 5V2.1A USB output port for wired charging. It is not only compatible with smartphone devices, but also tablet devices such as the iPad Air 2, iPad mini 3 and any other compatible device that requires a more demanding power solution.
Key Features of the TX-P2 10,000mAh Wireless Charging Power Bank at a Glance:
Grade A 10,000mAh lithium-polymer battery cell
5V2.1A USB output port charges both smartphone and tablet devices
Easy power on/off with 6 LED power charging indicators
Qi compatible
TX-P2 10,000mAh Wireless Charging Power Bank suggested price: USD 79.99
More information on the TX-P2 10,000mAh Wireless Charging Power Bank is available online: http://www.luxa2.com/product.aspx?s=142
TX-100 Portable Wireless Charging Pad
The TX-100 provides a simple and easy way to wirelessly charge your Qi compatible device, without having to worry about connecting/disconnecting those troublesome cables. Whether you’re charging on your desk at work or charging in the comfort of your home, the TX-100 offers you the flexibility of fixed wireless charging anywhere and anytime.
Key Features of the TX-100 Portable Wireless Charging Pad at a Glance:
Easy to use
Dual wireless charging capability
Supports wired charging
Rubberized charging ring for extra stability
Qi compatible
TX-100 Portable Wireless Charging Pad suggested price: USD 29.99
M
ore information on the TX-100 Portable Wireless Charging Pad is available online: http://www.luxa2.com/product.aspx?s=136
TX-200 Dual Wireless Charging Station
The TX-200 is a dual wireless charging station, capable of wireless charging two Qi compatible devices simultaneously. It also supports wired charging in the form of a single 5V1A USB output port for multiple charging of devices; and in effect, a total of three devices can be charged at the same time.
Key Features of the TX-200 Dual Wireless Charging Station at a Glance:
Easy to use
Qi compatible
TX-200 Dual Wireless Charging Station suggested price: USD 54.99
More information on the TX-200 Dual Wireless Charging Station is available online: http://www.luxa2.com/product.aspx?s=115
The whole LUXA2 WPC collection is available in selected Fry’s Electronic stores throughout the US and is available from the official LUXA2 Amazon USA online store
