Everyon though that 5G is low latency and fast download speed. Yes, that is true if the cell you are connected is not congested. Imagine you are in a stadium or a concert pack with spectactors, there is a high chance that your mobile line will get very low data speeds. This is particularly deterimental for content creators who want to do a LIVE STREAM of the event, be it a Fireworks Display or at a crowded tourist attraction point.
Malyasia’s U Mobile introduces ULTRA5G Priority. By using Network Slicing. It virtually “slices” the 5G signal to give you your own dedicated lane that isn’t shared with the general public. Once you have paid for the express path, you can dedicated speed which is faster than the shared public speed.
To do this, you have to go into the MyUMobile app and burn a Priority Pass. Each one lasts for 3 hours. Once you have subscribe to the service you will see the status bar change to “UM ULTRA5G PRIORITY.”
You will need to have a compatible phone, preferably newer ones and must support 5G SA. Depending on your plan, you get between 1 to 12 of these 3-hour sessions a month. This is especially useful for uplink speed for live or downlink speed if you are downloading huge files.
There are two passes to choose from :
