You probably have seen 4G+ on your handset. Basically that is carrier aggregation by combining 2 bands to boost speeds. Some of the common combinations of a 2 CA include Band 3 + Band 7 (1800+2600). Some telcos even have 3 CA that includes Band 8 + Band 3 + Band 7 (900+1800+2600).
Singtel launched 5G+ today but their definition is that it now includes 700 MHz. Singtel 5G+ is an enhancement to the 5G network and the next evolution of 5G.
This network innovation includes the 700MHz spectrum — on top of the usual 2.1GHz and 3.5GHz bands and delivers a better combination of speed, capacity and coverage.
Enjoy extensive coverage even deep indoors, from underground carparks to lifts, with increased signal strength by up to 40%.
According to Singtel, your device is 5G SA must be compatible and 5G SA settings must be switched on.
From the description above, we would define 5G+ refers to 5G Carrier Aggregation (5G CA), depending on the carrier and region. Usually in the case of 5G+, we are referring to 5G SA bands. A common combination will be n28+n78 (700+3500) to boost coverage and speed.
Depending on the phone, some might show a 5G+ logo but some may not. Some phones define 5G+ as connecting to high frequency 5G band e.g.. 3500 MHz (n78). So, don’t be alarmed if you don’t see a 5G+ icon on your handset.
It is important to note that there is no official definition of 5G+, the operator might trigger a 5G+ icon when it see a 5G running on C band or probably 5G SA 2CA depending on how it defines it in the firmware. Depending on the phone, it might not even show a 5G+ icon.
Here are some phones that support 5G+ (5G CA):
Flagship Phones with 5G+ Support
✅ Apple
- iPhone 15 series
- iPhone 14 series
- iPhone 13 series
✅ Samsung
- Galaxy S24, S24+, S24 Ultra
- Galaxy S23, S23+, S23 Ultra
- Galaxy Z Fold5, Flip5
- Pixel 8, Pixel 8 Pro
- Pixel 7, Pixel 7 Pro
- Pixel 6, Pixel 6 Pro
✅ Xiaomi
- Xiaomi 14, 14 Pro, 14 Ultra
- Xiaomi 13, 13 Pro, 13 Ultra
- Redmi K70 Pro
✅ OnePlus
- OnePlus 12, 12R
- OnePlus 11
✅ Oppo / Vivo
- Oppo Find X7, X7 Ultra
- Vivo X100, X100 Pro
✅ Sony
- Xperia 1 V
- Xperia 5 V
How to Check if Your Phone Supports 5G+?
- Carrier Support – Not all networks enable 5G CA for every phone. Check with your carrier.
- Band Compatibility – Look for NR CA (New Radio Carrier Aggregation) in specs
- Settings – Some Android phones show “5G+” in network status when connected to Carrier Aggregation.
