Features
Contents
Features
Qualcomm® Snapdragon™ 675 AIE Octa-core
processor upto 2.0GHz Adreno 612 GPU, upto 845MHz
4+64 / 6+128
4+64 / 6+128 Supports storage expansion up to 256GB
*Actual free memory and capacity may vary due to various factors. As the operating system occupies a portion of the RAM, actual available memory is less than stated. As the phone comes with pre-installed applications, the actual storage size is smaller than stated.
Camera
48MP+5MP AI Dual rear camera
Rear Camera
48MP + 5MP AI Dual camera
1.6μm large pixel (4-in-1 Super Pixel)*
PDAF
f/1.79 aperture lens
Steady handheld night photography
AI Portrait mode, background blurring
Single-tone flash
Low light enhancement
Standard HDR
Auto HDR
Video stabilization (EIS)
Burst mode
Panorama mode
Face recognition
AI Dynamic bokeh
AI Studio lighting
Video
4K, 30fps
1080p, 60fps/30fps
720p, 30fps
720p slow motion, 120fps
1080p slow motion, 120fps
Front camera
13MP
AI Beautify
Face recognition
Selfie timer
HDR
AI Studio lighting*
AI Scene detection
Rear camera: 33 scene categories
Front camera: 12 scene categories
Display
16cm (6.3) FHD+ Dot Notch Display19.5:9 aspect ratio
Resolution: 2340×1080 FHD+, 409 PPI
Contrast: 1500:1 (typ)
NTSC: 84% (typ)
Sunlight display
Night display
Reading mode
Color temperature adjustment
Standard mode
Charging and battery
4000mAh (typ)* / 3900mAh (min)
Supports Qualcomm®️ Quick Charge™️ 4 technology
5V/2A charger included
Type-C charging port
Built-in rechargeable battery
Dimensions
Height: 159.21mm Width: 75.21mm
Thickness: 8.1mm Weight: 186g
Networks and
Connectivity
3-choose-2 hybrid SIM tray
When using both SIM card slots, either card can be set as the primary card, which supports
4G+/4G/3G/2G calling and data
Network Bands
GSM B2/3/5/8
WCDMA B1/2/5/8
FDD-LTE B1/3/5/7/8
TDD-LTE B40/41(120MHz)
Connectivity
Supports protocols: 802.11a/b/g/n/ac
Supports 2.4G WiFi / Supports 5G WiFi / Supports WiFi Direct/ Supports WiFi Display
Supports Bluetooth 5.0
Fingerprint sensor and buttons
Navigation and
positioning
- GPS
- AGPS
- GLONASS
- Beidou
Sensors
- Gyroscope
- Accelerometer
- Proximity sensor
- Electronic compass
- Fingerprint sensor
- Ambient light sensor
- Vibration motor
- IR blaster
Multimedia
- MP4
- M4V
- MKV
- XVID
- WAV
- AAC
- MP3
- AMR
- FLAC
Supported video formats: H.265 / HEVC (Main profile), H.264 (Baseline / Main / High profile), MPEG4 (Simple profile / ASP).
Supported audio formats: PCM, AAC / AAC + / eAAC +, MP3, AMR – NB and WB, FLAC, WAV.
It also lack band 28
It lack band 38 for 4G+ on Singtel and starhub network
For starhub some parts of Singapore got band 38
And also TPG is going to use band 38 in the future as they won the extra specturm in the general specturm auction
And also band 28 in the future for the 3 big telcos
TPG won’t use band 38. It will use band 41
