Gigabyte Z390 AORUS PRO WIFI motherboard preview
Detail photos of motherboard
Contents
For gamers, the ALC1220-VB audio IC would bring out the best audio quality during gaming or music listening.
LGA1151 supports both Gen 8 and Gen 9 processors
4 DIMM slots supporting up to 64 GB of DDR4
Chipset Z390 and connectors on the left
6 SATA 6 Gbps ports
In terms of cooling, the motherboard incorporates a 12+1 Phases Digital VRM solution with DrMOS. It also uses screwed on mounted MOSFET heatsink to keep things cool. The DUal PCIe Gen 3 x 4 M.2 comes with thermal guards.
RGB Fusion
Stay tuned to http://en.ocworkbench.com and https://www.facebook.com/ocworkbench for more updates
Leave a Reply
Your email address will not be published.
