ADATA Launches Two DDR4 Memory Module Lines in Singapore and Malaysia
Premier DDR4 2133 U-DIMM and XPG Z1 DDR4 Overclocking Memory
Taipei, Taiwan – August 19, 2014 – ADATA™ Technology, a leading manufacturer of high-performance DRAM modules and NAND Flash application products, today launches two DDR4 line the Premier DDR4 2133 Unbuffered DIMM and XPG Z1 DDR4 Overclocking Memory which support the latest Intel® Haswell-E platform for extreme performance. Thanks to the benefits of DDR4 and rigorous production of ADATA, these DDR4 memory modules are an excellent upgrade solution for PC DIY users, by providing faster clock frequencies and lower power consumption.
With speeds of up to 2133MHz and a transfer bandwidth reaching 17GB/s, the Premier DDR4 2133 Unbuffered DIMM provides greater efficiency of data transfer than previous generations of DRAM. Compare to DDR3, the new DDR4 2133 Unbuffered DIMM can save 20% of the power, making it an environmentally friendly component.
With speeds of up to 2800MHz, timings of CL 17-17-17 and transfer bandwidth reaching 22GB/s, the XPG Z1 provides improved efficiency of data transfer. Only 1.2V is required to achieve high clock frequency of 2800MHz for overclockers. In addition, the SPD (Serial Presence Detect) of the XPG Z1 allows direct application without changing settings in the BIOS, facilitating usage and system stability.
The XPG Z1 features a jet wing-inspired design with carbon texture used for race cars, symbolizing the pursuit of extreme performance. Thanks to the unique Thermal Conductive Technology and 10-layer PCBs with 2oz copper, the chips in XPG Z1 can contact with the heat sinks directly, ensuring IC and PCB operate in an environment of equal temperature, as well as reduce electric resistance and consume less power, which greatly enhances the quality of signal transfer.
Top Quality & Lifetime Warranty
All ADATA memory modules are produced and tested by a rigorous quality control process for rapid computing and stable operation. In addition, ADATA memory modules provide customers a lifetime warranty for the maximum assurance with excellent service.
11-P-Premier-U-DDR4-2133-Dual_16GB_07 XPG_Z1_02_300dpi_07
