The Radeon HD 6990 aims to return AMD to the king the GPU roost, and the card upsizes just about everything. Simple extrapolation of the cards dimensions based on the photos indicate that the HD 6990 will go outside the 10.5″ GPU standard, appearing to be approximately 12-inches in length. It features only a single DVI connector, with 4 display ports allowing for 5 display Eyefinity on a single card. Power is provided by dual 8-pin PCIe connections, indicating a potential power draw of around 300W, but you can expect AMD’s PowerTune technology to keep it all in check.
