Apple just release it’s iOS 5.0.1 to fix the power drain issue. This firmware can be downloaded automatically over WIFI saving you the trouble of updating it through itunes with USB cable.
It is 38.9MB in size and it does the following :
– it fixes bugs affecting battery life
– Resolves bugs with Documents in the Cloud
– Improves voice recognition for Austrailan users using dictation
