Last week, we posted about the new ASRock P55 board supporting front USB 3.0. Today, we have news that ASRock will release 2 AMD equivalent board. This new board is the ASRock 890FX Deluxe4. It has 2 x Front USB 3.0 ports, 2 x Rear USB 3.0 ports, 8 x SATA3 connectors, 2 x IEEE1394 ports for exapansion. The rest of the specifications are quite similar to the 890FX Deluxe3. The other board is ASRock 890GX Deluxe4 which uses the integrated graphics chipset. It supports 5 SATA3 ports instead. The USB 3.0 is supported by NEC USB 3.0 chip while the extra SATA3 ports are supported by the Marvell chipset (on 890FX)
– World’s First AMD 890FX Motherboard
Supporting Front USB3.0
– ASRock DuraCap (2.5 longer life time),
100% Japan-made high-quality Conductive
Polymer Capacitors
– Phenom II X6 6-Core CPU Ready
– Supports ASRock Turbo UCC
– Supports ASRock UCC – Unlock CPU Core
– Supports Dual Channel DDR3 1866(OC)
– Supports ATITM Quad CrossFireXTM,
3-Way CrossFireXTM and CrossFireXTM
– 2 x Front USB 3.0 ports, 2 x Rear USB 3.0 ports,
– Dr. Debug, Smart Swith Design: Power/Reset/
Clear CMOS Switch with LED
– Supports ASRock Instant Boot, Instant Flash,
OC Tuner, IES, OC DNA, Good Night LED,
Multi-Speed Fan Control, AIWI, APP Charger
– 7.1 CH HD Audio with Content Protection
(Realtek ALC892 Audio Codec),
THX TruStudio PROTM and Premium Blu-ray
audio support
– Free Software : CyberLink DVD Suite – OEM and
Trial
– ErP/EuP Ready
6 thoughts on “ASRock introduces world’s first AMD front USB 3.0 capable boards – ASRock 890FX Deluxe4 and ASRock 890GX Deluxe 4”
  1. […] ASRock kembali bersiap menambah lineup produk motherboard terbaik mereka yang kaya akan fitur, belum puas dengan motherboard seri Deluxe3 kali ini ASRock telah siap akan meluncurkan seri Deluxe4 yang memiliki 2 macam model yang sama-sama berbasis chip platform AMD yaitu 890FX Deluxe4 dan 890GX Deluxe4. Kedua produk motherboard tersebut dilengkapi dengan 4 port USB 3.0, 2 port pada panel belakang dan 2 lainnya di panel depan. Masing-masing dipersenjatai dengan 4 slot memory DDR3, eSATA, 7.1 channel audio, debug LED, PCI-E CrossFireX ready pada 890FX Deluxe4 dan untuk 890GX Deluxe4 mendukung Hybrid CrossFireX serta di-backup dengan Radeon HD 4290 integrated graphics, 8 port SATA 6.0 Gbps untuk 890FX sementara 5 port untuk 890GX. Masih belum ada konfirmasi tag harga untuk motherboard ASRock 890FX Deluxe4 dan 890GX Deluxe4 namun kemungkinan sudah akan mulai tersedia beberapa minggu kedepan. source […]
Comments are closed.
