890GX Extreme3
Features
.png)
UCC (Unlock CPU Core) feature simplifies AMD CPU activation. As long as a simple switch of the BIOS option “Unlock CPU Core”, you can unlock the extra CPU core to enjoy an instant performance boost.
.jpg)
ASRock True 333 motherboard series offer the unmatched performance with the onboard acceleration of the latest USB3.0 with advanced 10X faster speed; SATA3 technology supports up to 12Gbps data transfer speed (via RAID 0), and the most convenient connectivity of eSATA3 devices. To enjoy a completely true computing, ASRock True 333 series motherboards can run the PCI-E for VGA card, SATA3 and USB 3.0 at full speed together simultaneously.
more…
.jpg)
.jpg)
![]() Clear CMOS Switch |
![]() Power Switch |
![]() Reset Switch |
.gif)
EuP / ErP, stands for Energy Using Product, was a provision regulated by European Union to define the power consumption for the completed system. According to EuP / ErP, the total AC power of the completed system shall be under 1.00W in off mode condition. To meet EuP / ErP standard, the EuP / ErP ready motherboard and the EuP / ErP ready power supply are required. (The EuP / ErP ready power supply must meet the standard of 5v standby power efficiency is higher than 50% under 100 mA current consumption.).
more…
.png)
An outstanding technology developed on ASRock motherboard! It provides the excellent audio output of 24-bit/192 kHz with its respective Blu-ray DRM compatible driver/software.
more…
.png)
OC DNA, it’s an exclusive utility developed by ASRock’s outstanding RD team, provides a convenient way for user to share the OC settings with others. It helps you to save your overclocking settings under the operating system and simplifies the complicated recording process of overclocking settings. With OC DNA, you can save your OC settings as a profile and send the profile to your friends! Your friends then can load the OC profile to their own system to get the same OC settings as yours!more…
.png)
ASRock has overcome the technical obstacles and exclusively invented a new technology that allows you to turn on your PC and boot up to Windows® in 4 seconds! ASRock Instant Boot not only excels in the Boot Up speed (3~4 sec.), it also provides clean OS, and saves the most power energy.
.gif)
ASRock Instant Flash is an exclusive and the most user-friendly BIOS flash utility developed by ASRock. It is embedded in Flash ROM which is used to update the system BIOS without having to enter operating systems like MS-DOS or Windows.
.png)
ASRock software suite is designed with the customer-oriented concept, delivers the best possible experience for today’s most demanding users. The Sound Blaster X-Fi MB solution ensures you the premium audio quality, effects and features for PC systems equipped with onboard audio. For instance, the X-Fi CMSS-3D technology expands your stereo audio into surround sound via multi-channel speaker, stereo speaker or even headphone; the X-Fi Crystalizer technology restores the compressed sound source and can even let you hear every detail in riveting surround sound. Combined with the Creative user-friendly software and the ASRock high performance motherboard, you will be assured to enjoy a rich variety of programming and be entertained by a better way.
.gif)
Dr. Debug helps you to diagnose the BIOS POST status of your system.
.gif)
Heatpipe with fan design for CPU power Mosfet
(M).gif)
Key features of DirectX 10.1 include an updated shader model, improved anti-aliasing support, more flexible data access, and tighter specifications for better applicationcompatibility.
(M).gif)
Boost performance up to 8.13% which is rarely seen on other 890GX boards.
