We have seen the ASRock X58 Extreme with USB 3.0 support. ASRock up it’s ante by introducing yet another high end board, the ASRock X58 Extreme6. The most important changes to this board is that it now supports 6 USB 3.0 ports, 6 SATA 6Gbps ports. it also supports 6 core CPU. That is why it is known as Extreme 6!
Below are the specs:
ASRock DuraCap (2.5 x longer life time), 100% Japan-made
high-quality Conductive Polymer Capacitors
– Six-Core CPU Ready
– Supports Triple Channel DDR3 2000(OC)
– Supports ATITM Quad CrossFireXTM,3-Way CrossFireXTM and
CrossFireXTM
– Supports NVIDIA® Quad SLITM,3-Way SLITM and SLITM
– 2 x Front USB 3.0 ports, 4 x Rear USB 3.0 ports, 6 x SATA3 6.0
Gb/s connectors, 2 x IEEE1394 ports
– Dr. Debug, Smart Swith Design: Power/Reset/Clear CMOS
Switch with LED
– Supports ASRock Instant Boot, Instant Flash, OC Tuner, IES,
OC DNA, Good Night LED, Multi-Speed Fan Control, AIWI,
APP Charger
– Combo Cooler Option (C.C.O.)
– 7.1 CH HD Audio with Content Protection (Realtek ALC892
Audio Codec), THX TruStudio PROTM and Premium Blu-ray
audio support
– Free Software : CyberLink DVD Suite – OEM and Trial
– Free Bundle: 1 x Front USB 3.0 Panel, 1 x ASRock SLI_Bridge_
2S Card, 1 x ASRock 3-Way SLI-2S2S Bridge Card
– ErP / EuP 2.0 Ready
[…] OCWorkbench AKPC_IDS += "2074,";Popularity: 6% [?] Adverts Computers […]
[…] soluciones atípicas y por atreverse con diseños poco comunes, y lo ha vuelto a demostrar con la recién desvelada X58 Extreme6, un modelo equipado con seis conexiones USB 3.0 y seis puertos SATA 6.0 Gbps que hará las delicias […]
[…] Fuente Categorías: Destacados • Noticias • Tarjetas Madres Tags: 1366 • ASRock • Extreme 6 • X58 […]
[…] Source: OCWorkbench […]
[…] Instant Boot, Instant Flash, and OC Tuner. One can expect the board to be out soon. Source: OCWorkbenchMore: ASRock Readies X58 Extreme6, Motherboard with Six SATA 6 Gb/s and USB 3.0 Ports Filed under: […]
[…] OCWorkbench Posted in Tech Power Up! « HBO Plans to Expand HBO Go to More Devices, Systems Both […]
