ASUS Announces the MS-100 USB Speakers and HS-W1 Wireless USB Headset
Crisp, clear and compact USB sound products that are easily packed for travel, as ideal notebook companions
Singapore (January 06, 2012) — ASUS has announced two new USB sound products, the MS-100 compact USB stereo speaker set, and HS-W1 wireless USB headset. Both are designed with sharp, striking looks, fantastic audio quality and a pure Plug ’n Play design, but with a minimal size that’s easily packed and to travelled with.
MS-100 USB Speaker
The MS-100 is a compact stereo USB speaker set, powered entirely by a USB 2.0 (or 3.0) port, yet still capable of providing punchy sound without distortion. Its minimalist and strong Art Deco cone design mimics the classic speaker shape, making them a perfect feature for any home or office environment. Meanwhile inside, its large 54mm speaker drivers can generate up to 93dB of sound with less than 3% distortion for its rich highs, thumping mids and full low tones.
No additional software driver is required on Windows® Vista® or Windows® 7 machines, making it suitable for any desktop or laptop that needs an immediate sound boost!
Providing clear, crisp sound in total comfort, the HS-W1 headset is built with large 70mm leather earpads for long lasting, natural comfort. The 2.4GHz wireless technology used with the HS-W1 headset allows CD quality sound (44.1KHz/16-bit, uncompressed) to be transmitted from the tiny USB dongle to the headset, while also offering twice the remote distance of Bluetooth audio. Combined with the acoustic tuned 40mm drivers with a built-in equalizer, it promotes voice tones and fine details, with a hint of extra bass punch where it’s needed.
The noise filtering microphone highlights speech tones, while its simple rotate-to-mute design is ideal compared to blindly searching for a small button while you’re on-call. The large on-ear volume controls also make it easily adjustable with a simple tap, without the hassle of a small and fiddly in-line remote.
With up to 8 hours operating time on its in-built rechargeable battery, the light 170g folding design and bundled touring case means the HS-W1 is an ideal travel companion.
For further product information, please visit www.asus.com.
HS-W1 Specification | |
Wireless Technology | Wi-Fi 2.4GHz advanced 2-way digital transmission |
Distance of Use | Up to 15 meters |
Headset Speaker | 40mm, ultra-high performance |
Headset Mic | Noise cancellation clarity |
Frequency Response | 20 ~ 20k Hz |
Listening Time | Up to 8 hours |
Battery Type | Lithium polymer |
Product Dimensions | 180 x 175 x 65mm |
Weight | 170g |
MS-100 Specification | |
Speaker Driver Dimension | 54mm high performance |
Frequency Response | 100 Hz~ 20KHz |
RMS | 2x 1.5W |
Power Supply | 500mA powered by USB (power-adapter free) |
Connection | USB 2.0 (USB 3.0 compatible) |
Product Dimensions | 152 x 104 x 133mm |
