USB-AC53 puts to the test
First, we use the speedtest.net app to test the speed against 3 other configurations.
The 4 configurations are :
Notebook used : HP Envy 14
– ASUS RT-AC66U and USB-AC53 802.11ac adapter (up to 886Mbps)
– ASUS RT-AC66U with notebook’s direct Ethernet connection
– ASUS RT-AC66U with notebook’s internet Broadcom WiFi-N (300Mbps) WiFi connection
– ASUS RT-AC66U with Zyxel 802.11n (300Mbps) USB Stick
The router is set as two networks, the first is the 2.4GHz and the second SSID is the 5GHz band.
In the test, the notebook is connected to the router via the 5GHz band.
In the speedtest test, it is run against SGIX server.
From the results, we can see that the speeds obtained are very closed to a wired connection. In fact, with the ASUS router, even the internal WiFi-N and Zyxel USB Stick comes close to the wired speed but is just a bit slower than the ASUS+ASUS combination.
When we used the same HP notebook’s internal WiFi-n to connect to our WD N900 Central, we only managed 89-90Mbps on the 5 GHz band connection.
Oh my goodness! Incredible article dude! Thanks, However I am
experiencing problems with your RSS. I don’t understand the
reason why I am unable to join it. Is there anybody getting identical RSS problems?
Anyone that knows the answer will you kindly respond?
Thanks!!
Attractive section of content. I just stumbled upon your website
and in accession capital to assert that I get in fact enjoyed account your blog posts.
Anyway I will be subscribing to your augment and even I achievement you
access consistently rapidly.
