BIOSTAR Officially Launches Latest AMD “Trinity” Based Hi-Fi Motherboard with Exclusive Integrated BIOSTAR Hi-Fi Technology
September 19, 2012, Taipei, Taiwan – BIOSTAR, a manufacturer of motherboards, VGA cards, industrial computer systems and other peripherals, has officially launched their latest edition to their high-end motherboard lineup, the Hi-Fi A85X. This newest ATX form factor motherboard supports all AMD Socket FM2 CPUs and offers native support for SuperSpeed USB 3.0 and dual-channel memory up to DDR3 – 2400 in over-clocking mode. Socket FM2 is a CPU socket used by AMD’s upcoming Trinity Fusion APU’s which will also utilize AMD’s new A85X chipset. The Hi-Fi A85X has also received the official Windows 8 hardware certification from Microsoft.
One feature set that sets the BIOSTAR Hi-Fi A85X above and beyond typical motherboards is the integrated BIOSTAR Hi-Fi technology called “Puro Hi-Fi Technology”. Marketing Manager Eric Tung gets excited when given a chance to explain the value proposition with these motherboards. “It’s pretty cool how we have put a unique power delivery system just for the audio aficionados out there, like me” explained Eric. “With our professional quality sound and video capabilities on this board, a user can set up a full PC based home theater system with full THX support and true 7.1 surround sound…I mean the real thing, this isn’t simulated. You have to hear it to believe it”, he enthused.
Targeting audiophiles, HTPC enthusiasts and high-end gamers alike, Puro Hi-Fi sports an integrated independent audio power design with a built-in amplifier. The technology utilizes audio components with an independent power design for a significant reduction in electronic noise producing superb sound quality. The unique noise-blocking multi-layer PCB layout is conducive for an exceptionally clean signal. That design feature, together with a sampling rate of 192kHz/24-bit, delivers a high quality audio through an analog connection to your home theater system, multi-channel speakers or high-end headphones allowing you to enjoy true high-definition 7.1-channel surround sound.
Part of the Puro Hi-Fi design includes high-quality “Non-Polarized Electrolysis Electric audio capacitors” for each individual audio channel circuit delivering low noise, low distortion, and a wide bandwidth to achieve the highest sound resolution and sound expansion for the most realistic sound effects. Furthermore, the resistors used by the system are of the metal-oxide film type with metal oxides such as tin. The electric characteristics are that of greater stability and reliability than regular metal film resistors when operating in an extremely broad working temperature range. These special components are typically used in applications with high endurance audio demands.
With BIOSTAR’s implementation of four unique technologies, Puro Hi-Fi, THX, Lucid MVP and SmartSpeedLAN, the brand new Hi-Fi series of motherboards increases sound, network and graphics performance dramatically. For a powerful gaming masterpiece with even a limited budget, this new Hi-Fi series motherboard is the best choice and will become a new favorite among gamers and movie watchers.
