BIOSTAR Reveals the TA970 Plus AMD Mainboard with Advanced Clock Calibration
March 9th, 2015, Taipei, Taiwan – BIOSTAR has released an AMD socket AM3+ motherboard, the TA970 Plus with AMD OverDrive™ and the ACC (Advanced Clock Calibration) feature. This AMD 970 chipset board supports AMD multi-Core (x8, x6) and Socket AM3 processors including the AMD FX/ Phenom II and Athlon II versions. This is a powerful platform for gamers and enthusiasts.
The TA970 Plus is a full sized ATX board with 4 DDR3 DIMM slots and mSATA/Mini PCI-E combo connector. It supports SATA 6Gb/s speeds, which are two times the speed of current SATA 3G. Of course there is USB 3.0 support as well. Powerful graphics are supported with AMD’s CrossfireX capability.
To get every power advantage the TA970 Plus features the AMD OverDrive™ and the ACC (Advanced Clock Calibration) function. This allows power users to overclock their system by precisely calibrating the clock timings between the processor and RAM chips. These timings are critical in maintaining system stability when overclocking, otherwise you will end up with a system that crashes often. As they say, “Timing is Everything” and the TA970 Plus allows you to get it right.
Premium BIOSTAR exclusive features of the TA970 Plus include the BIO-Remote II, Smart Speed LAN and PURO Hi-Fi technology. The PURO Hi-Fi technology features an integrated independent audio power design with a built-in amplifier. The technology utilizes audio components with an independent power delivery design for a significant reduction in electronic noise producing superb sound quality. The unique noise-blocking multi-layer PCB layout is conducive for an exceptionally clean signal. That design feature, together with a sampling rate of 192 kHz/24-bit, delivers high quality audio through an analog connection to your home theater system, multi-channel speakers or high-end headphones, allowing you to enjoy true high-definition 7.1-channel surround sound.
For more on the TA970 Plus go to: http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=787
