ASUS will be releasing two new ROG Extreme series motherboards that provides amazing overclocking capabilities for bother AMD and Intel platform.
The Rampage III Extreme (Intel® X58 chipset) and Crosshair IV Extreme (AMD® 890FX chipset) each offer four PCI-E x16 slots for mind-blowing frame rates with quad-card NVIDIA SLI and ATI CrossFire X set-ups, but both motherboards also make it easier than ever to squeeze more performance out of more mainstream rigs.
With the flick of a switch, ASUS ROG Connect repurposes a USB port on each Extreme Series motherboard to enable remote access to overclocking features from a second PC. The proprietary iROG processor allows real-time status monitoring on a laptop via a USB connection and the RC TweakIt applications provides a simple way to adjust overclocking parameters on-the-fly.
ROG Connect also provides a straightforward recovery system for over-enthusiastic overclockers and the RC BIOS Flashback feature lets you re-flash the BIOS from a backup using a second computer. RC Remote also provides remote reset, shutdown and CMOS clearing over a USB connection for fool-proof fine-tuning.
Overclockers looking for the ultimate in remote control need look further than ROG Connect’s RC Bluetooth feature. With software installed on a compatible smartphone,  overclocking adjustments can be made wirelessly over a Bluetooth connection — just the thing for hectic LAN parties where trailing cables are the very last thing you need.
2 thoughts on “[CeBIT 2010] ASUS makes overclocking easy with Extreme Series of motherboards Rampage III Extreme (Intel® X58 chipset) and Crosshair IV Extreme (AMD® 890FX chipset)”
  1. After examine just a few of the weblog posts in your web site now, and I really like your approach of blogging. I bookmarked it to my bookmark web site list and can be checking again soon. Pls try my site as nicely and let me know what you think.
  2. I have read some just right stuff here. Certainly worth bookmarking for revisiting. I wonder how so much effort you put to make this kind of great informative site.
Comments are closed.
