Vision 3D-BD
Are you looking for small footprint device as your media centre in your living room. The ASRock Vision 3D-BD might be an excellent choice.
Based on Intel core Architecture Mobile processor running on Intel HM55 chipset, it definitely outperforms the previous generation ION 330HT-BD system we reviewed before.
In terms of specs wise, this box is capable of 3D vision by virtue of NVIDIA GeFOrec 300/400 series graphcis within.
Other than that, this board uses DDR3-1066, 2 x SO DIMM supporting up to 8 GB of RAM. It uses a 2.5″ HDD and comes with BD Combo drive.
In terms of audio, it has a 7.1ch HD audio with THX trustudio pro. Gigabit LAN is onboard for faster conenctions to files on other servers.
The box also comes with HDMI, DVI-I, USB 2.0, card reader, esata ports etc. a MCE remote controller is also equipped. It has a dimension of 200 x 70 x 200 (mm) and a volume of 2.8L.
