Corsair® Expands Dominator® Family with New Ultra-High Density 16GB and 24GB Memory Kits
– Unmatched combination of speed and density ushered in with 1600MHz modules –
FREMONT, California, April 6, 2010 — Corsair, a worldwide supplier of high performance computer and flash memory products, today announced new 16GB and 24GB Dominator DDR3 memory kits for workstation-level computers. These DRAM kits feature a clock speed of 1600 MHz and a CAS latency of nine cycles.
The introduction of these new kits expands Corsair’s worldwide award-winning Dominator memory family, providing an exciting new level of performance for data-intensive computing applications.
Corsair’s 24GB Dominator DDR3 memory kit has been rigorously qualified and tested in platforms based on the Intel® X58 chip set. It is designed for use with three-channel CPUs such as the Core™ i7 980X processor. The 16GB Dominator DDR3 memory kit is designed for use on dual channel platforms based on the P55 chip set. Both module kits include Corsair’s patented DHX+ technology, and feature racing-blue highlights and fins.
“We continue to see increasing demand for high density solutions from programmers, scientists, videographers, and other data-intensive users,” stated John Beekley, VP of Technical Marketing at Corsair. “These new 1600MHz modules will enable a new level of processing speed for handling these large data sets.”
The 16GB and 24GB 1600MHz Dominator DDR3 memory kits are available immediately from the Corsair Store.
About DHX+ Technology
Corsair’s innovative DHX+ technology uses specially designed, high-quality heatsinks and a custom-designed PCB that allows both the front and rear of the memory ICs, and the printed circuit board itself, to be cooled. DHX+ technology also allows for the cooling fins to be removed, allowing for a range of modular cooling accessories including extended heatsink fins, the Corsair Cooling™ Hydro Series H30 water cooling block and Corsair Cooling™ Ice Series T30 sub-ambient cooling subsystem, which cools the memory up to 20°C below room temperature for maximum overclocking performance. Corsair DRAM modules with DHX and DHX+ are covered by US Patent number 7,606,034.
