COUGAR’S Cutting Edge Mouse Pad Technology
August 14th 2014, Taipei – COUGAR, leading eSports and computer peripherals brand has launched two new gaming mouse pads, the SPEED and CONTROL. Both types come in 3 different sizes and both are perfect for use with regular mice or high-end gaming mice like the COUGAR 700M gaming mouse, the adjustable gaming mouse dedicated to professional gamers.
The new SPEED and CONTROL gaming mouse pads both feature an optimized 4mm thickness giving a thicker mouse pad cushion. This provides better pressure relief on the user’s wrist. And not too tall, at 4mm, the mouse pad cushions’ height strikes a balance between comfort and user friendliness.
cougar
The design of the foam cushioning pad doesn’t end there. Made with a natural rubber, all of the materials of these mouse pads are non-toxic. With a right angle wave structure and anti-slip natural rubber base, these mouse pads grip on all kinds of surfaces. This combination of a right angle structure and the rubber physically supports the mouse pad against outer forces from all different directions, and provides better stability. In addition, the combination of a cloth surface and a rubber base makes them very portable. Long term use is address as well. These mouse pads have a localized edge heating process applied to increase the durability and prevent fringe tearing on the sides.
Compatible with laser and optical mice, these pads work with high sensitivity settings and sensors and are best matched with high DPI mice. Both the SPEED mouse pad and the CONTROL mouse pad come in three different sizes to fit all gamers’ preferences.
cougar2
For the SPEED gaming mouse there is a high-definition textured surface. This design provides for a fast and extra smooth mouse sliding movements. Through the SPEED surface technology, gamers can enjoy the swiftness and smoothness that helps them to bring on fast and accurate movement. Indeed, the SPEED surface material was tested by multiple gamers under intensive gaming environment.
For those looking for more control versus speed, the CONTROL mouse pad features a rougher glide 3d textured surface. The CONTROL cloth texture provides a smooth and precise mouse targeting experience. With the 3D fabric textured technique, the CONTROL mouse pad can offer a proper friction for gamers to achieve meticulous targeting and tracking control. The CONTROL mouse pad also has a water resistance fabric which is easy to clean due to the unique water resistant surface so it protects against liquid spilling and staining accidents.
