Heaven Benchmark on ASRock 880G Extreme3
Bluetooth 24 Apr 2010
The same results can be seen from Heaven demo. At default, it only scored 5.2 fps. With the OCed GPU and Sideport, it increased to 7.4 fps. It is apparent that a higher GPU and sideport memory with stable performance is the main factor in determining the performance.
The 880 boards run well….
No display port? Really?
[…] Below is a picture of the CPU-Z, images of it running 3Dmark Vantge, hyperPI etc can be found here in the forum. You can also read the review here. […]
