Cinbench 10 benchmarks on the ASRock 880G Extreme3
Bluetooth 24 Apr 2010
In Cinebench 10, we
MAXON CINEBENCH runs several tests on your computer to measure the performance of the main processor and the graphics card under real world circumstances. The benchmark application makes use of up to 16 CPUs or CPU cores and is available for Windows (32-bit and 64-Bit) and Macintosh (PPC and Intel-based).
In this test, we compare theย 2 boards running Cinebench R10 (64 bits). We first run the test under default settings. The second test is with GPU overclocked and Sideport overclocked. The third test is with the 4th core enabled on the Phenom II X3 710.
As we can see from the chart, the ASRock 880G Extreme3 performance isn’t bad at all. The slightly lower scores could be due to a lower clk of 200.0mhz instead of the 200.4mhz on the ASUS board. Nevertheless, we see that the performance is pretty close to the 890GX even when the system is overclocked.
The 880 boards run well….
๐
No display port? Really?
[…] Below is a picture of the CPU-Z, images of it running 3Dmark Vantge, hyperPI etc can be found here in the forum. You can also read the review here. […]
