G.SKILL Officially Announces
Ripjaws 4 Series DDR4 Memory Kits
Extreme Speed Available Up to DDR4 3200MHz
G.SKILL International Co., Ltd., the leading high performance memory designer and manufacturer, reveals the long awaited next generation Ripjaws 4 series DDR4 memory kits! Featuring all new redesigned heatspreaders in three different colors, high performance frequencies, high capacity, DDR4 quad-channel ready, and ultra low voltages, the Ripjaws 4 series is all the benefits of DDR4 rolled into one sleek package.
Extreme Performance from 2133MHz to 3200MHz!!
With a standard of 2133MHz, DDR4 is the next generation definition of performance. Also available in 2400MHz, 2666MHz, 2800MHz, 3000MHz, and 3200MHz, the starting lineup is continuing where DDR3 left off. With capacities starting at 16GB (4GBx4), 32GB (8GBx4 / 4GBx8) and 64GB (8GBx8), your new X99 platform will have more memory space to do what you need it to do. That’s not all! Ripjaws 4 also has an ultra low voltage rating of 1.2V for kits under 2800MHz and 1.35V for 3000/3200MHz!
XMP 2.0 Support on Next Gen Intel® X99 Quad Channel Platforms
Sometimes, simplicity is best. Ripjaws 4 series memory kits above 2400MHz support Intel XMP 2.0 for automatic and trouble-free tuning. Working closely with the major performance motherboard partners, Ripjaws 4 series DDR4 memory are validated for compatibility with most upcoming X99 motherboards with a series of rigorous tests under quad channel memory operations. It’s guaranteed to provide the best-in-class performance, compatibility, and stability with a wide range of X99 motherboards.
All-New Designed Heatspreaders Available in 3 Colors
As the 4th evolution of the Ripjaws series, Ripjaws 4 is outfitted with an all-new designed heatspreader. Available in Red, Blue, and Black! And don’t worry; Ripjaws 4 has a module height of 40mm – the same height as previous Ripjaws family modules – and will be compatible with most CPU heatsinks!
