Get unlimited cashback from your favourite brands when you shop with the BigPay card in Singapore!
If you are not a BigPay user, you can sign up using our referral link.
Hey! Use the code IEW3Q2R2P3 when you sign up to BigPay and get S$5 for you to spend as soon as you activate your card.
Just register on the app using this link:
http://bigpay.link/referrals and enter this code
IEW3Q2R2P3 for $5
Here’s a sneak peek:
  • Sports & Athleisure – Nike, Lululemon, JD Sports, Decathlon
  • Fashion – Zalora, Pomelo Fashion, Charles & Keith
  • Health & Beauty – Sephora, Watsons, Kinohimitsu
  • Travel – Singapore Airlines
  • Misc – Kinokuniya, Sonno, Lazada, Dell
Powered by Pulse iD
Follow these steps to get unlimited cashback:
Step 1: Open your BigPay app and tap ‘Explore’
Step 2: Tap ‘Cashback & Rewards’ then scroll down to ‘Unlimited Cashback’
Step 3: 🔥 Once you’ve found your desired brand, click on it then tap the ‘Shop At’ button
Step 4: 🔥 Checkout your cart with the BigPay card
🔥 IMPORTANT:
You must use the redirected link from the ‘Shop At’ button AND checkout with your BigPay card. Otherwise, you won’t be eligible for cashback. 😞
IEW3Q2R2P3 for $5
