BIOS Options
The BIOS is still the text based BIOS that we are used to. First of all, we check out the options available.
Under the MB Intellitent Teweaker, you can set the VGA core clocko from 300 – 2000MHz, the default is 500MHz.
Next the host clk frequency can bve set from 100 – 120MHz. Memory clock can be 5.33x or 6.66x (DDR3-1066 or DDR3-1333).
Voltage range of DDR3 ranges from Normal 1.2 to 2.1v. FCH from 1.10v to 1.60v. PCIe PLL voltage can range from 1.80v to 2.20v. CPU NB VID can range from to -0.6v to +0.025v. CPU Voltage control ranges from -0.6v to +0.60v.
