GIGABYTE Extends Super Overclock Series with GTX 470 SOC Graphics Card
— Gauntlet™ sorted GPU with the latest in-house cooling design WINDFORCE™ —
Taipei, Taiwan, August 6th, 2010 – GIGABYTE, a leading manufacturer of motherboards and graphics cards, introduces a powerful new addition to its Super Overclock Series: GTX 470 SOC (GV-N470SO-13I). To qualify for Super Overclock Series, a GPU must go through GIGABYTE’s innovative GPU Gauntlet™ Sorting process and it must be equipped with Ultra Durable VGA or VGA+ boards. Designed specifically for overclocking competition and gaming battle, GIGABYTE’s secret weapon GTX 470 Super Overclock Edition is built with NVDIA GeForce GTX 470 GPU. Based on 40nm processor and advanced GDDR5 memory technology, the powerful new GPU consists of ground-breaking features including Microsoft DirectX® 11 and NVIDIA PhysX™ which leads to incredibly immersive HD gaming experience and unrivaled performance. GV-N470SO-13I also features WINDFORCE™ 3X, 14 phase PWM design, OC Guru graphic card smart tuner and voltage read point.
WINDFORCETM – GIGABYTE’s Latest Cooling Solution
GIGABYTE introduces WINDFORCE™, the latest cooling technology that differentiates the brand’s graphics cards from the rest. GIGABYTE understands that a fan is crucial to the graphics card, so only the fan with the most efficiency is selected for WINDFORCE™. To qualify for WINDFORCE™, the cooling solution must be equipped with anti-turbulence inclined-fin, ultra quiet PWM fan and pure copper heat pipe. Inclined-fins redirect airflow and help to reduce excessive heat and turbulence. Depending on its orientation, there are 3 types of inclined-fin designs: parallel-inclined, mirroring-inclined and 3D-inclined. Each type contributes to generating excellent exterior airflow for efficient heat dissipation from the interior GPU core.
WINDFORCETM 3X: Anti-turbulence Cooling
GV-N470SO-13I is equipped with WINDFORCE™ 3X cooling solution. WINDFORCE™ 3X features 3 ultra quiet PWM fans. The special inclined triple-fan design effectively minimizes the flow of turbulence between three fans. With a unique vapor chamber, WINDFORCE™ 3X is able to transfer heat from the hot spot to the cool spot as thermal energy becomes evaporated to the surrounding air. By capillary action, the condensed liquid droplets circulate back to the base of chamber. The cycles of evaporation and condensation enhance heat dissipation for greater cooling efficiency. Moreover, WINDFORCE™ 3X is equipped with three copper heat pipes to strengthen the speed of heat dissipation.
Pure Power Architecture
GV-N470SO-13I has incredibly pure power. It is compatible with ATX standard length PCB. 14 phase PWM design includes 12 for GPU, 2 for memory. Standard GTX 470 graphics card has five power phases whereas GIGABYTE’s GTX 470 SOC has 12, two times the reference card. Not only does GV-N470SO-13I have three times power phases than reference card, the 12 power phase status LED indicators indicate graphics card’s current power phase, helping users monitor power consumption. This feature ensures a more stable system and better overclocking capability.
GIGABYTE’s very own GPU Gauntlet™ Sorting process is the key to the best GPUs for Super Overclock Series. A GPU must pass a sequence of tests to be selected. This unique process offers three major advantages. First, full-throttle performance tuning improves overclocking ability by at least 10% to 30%. Second, optimized thermal efficiency lowers extra temperatures by 5% to 10%. Fan speed is guaranteed at standard rpm in high-rated 3D and physics-accelerated games to reduce noise for an absolutely quiet environment. Lastly, expert power switching lowers power switching loss by 10% to 30%. With GPU Gauntlet™ Sorting, GIGABYTE SOC graphics card guarantees higher overclocking ability.
Ultra Durable VGA+
Thanks to Ultra Durable VGA+ that features 5+1 quality components, the Super Overclock Series supports top performance in graphics benchmarking. GIGABYTE Ultra Durable VGA+’s 5 proadlizers on graphics cards are able to provide 1.6 times purer power supply compared to traditional power design (zero proadlizers).
Proadlizer® Quintuple
One of the quality components of Ultra Durable VGA+ is GIGABYTE’s exclusive use of proadlizers. Unlike other leading brands that only use one proadlizer on their graphic cards, GIGABYTE generously uses five units of NEC Proadlizer®, also known as film capacitor, to provide amazing current capacity up to 5000uF and extremely low ESL/ESR for super overclocking ability. Five times the regular capacitance indicates the amount of electric energy stored is fivefold. By placing five proadlizers around GPU, electric currents are able to be charged and discharged rapidly to support super overclocking activity. The quintupled proadlizers transmit more stable power even during heavy loading.
OC Guru – Graphic Card Smart Tuner
GIGABYTE proudly improves its graphics card smart tuner OC Guru. This graphics card tweaking utility puts together the best combination of software/hardware overclocking. It now features 3 profiles: OC (for overclocking mode), Gaming (for gaming mode), and Green (for power saving mode). The different modes cater to users’ different needs. GIGABYTE’s distinctive adjustable software offers gamers to adjust tuners for memory, voltage, and fan speed. OC Guru, the user-friendly software, gives hardcore gamers liberty when overcloking.
Voltage Read Point
GIGABYTE’s specific voltage read point supplies hardcore gamers an ultimate benching experience at overclocking competition. Heavy users can change the voltage simply through software instead of manually adjusting any components on PCB. It is easy for overclockers to master the platform and monitor GPU workload at any time just through voltage read point.
The GIGABYTE Super Overclock Series includes HD 5870, HD 5770, GTX470, and upcoming GTX460. For more details about the Super Overclock Series, please visit the GIGABYTE VGA website at: http://www.gigabyte.com/products/main.aspx?s=43
GIGABYTE SOC: http://www.gigabyte.com/MicroSite/72/index.html
