— GIGABYTE Unveils Its First AMD Fusion™ Mini-ITX Motherboard at CES 2011 –Delivering Outstanding Integrated Graphics from a Low Power, Small Form Factor Hi-Def Home Entertainment Platform
Las Vegas NV, USA, January 4, 2011 – GIGABYTE TECHNOLOGY Co., Ltd, a leading manufacturer of motherboards, graphics cards and other computing hardware solutions today proudly announced its first ever Mini-ITX form factor motherboard for the AMD platform called the GA-E350N-USB3. The new addition to GIGABYTE’s small form factor HTPC motherboard range features AMD Fusion™ Technology with DirectX® 11, SuperSpeed USB (USB 3.0), SATA 6Gbps, an HDMI interface, as well as a host of unique high-end GIGABYTE features such as Ultra Durable™ 3 Classic, 3x USB Power and On/Off Charge for quick charging iPad, iPhone and iPod Touch devices.
“We’re excited about the GA-E350N-USB3 motherboard because it’s the first all-in-one Mini-ITX board with DX11 capabilities, and we expect it to go a long way towards bridging the gap between discrete and integrated graphics performance,” commented Tim Handley, Deputy Director of Motherboard Marketing at GIGABYTE Technology Co. Ltd. “With its specially designed low profile fansink and multitude of hi-def, high-speed connectors, we expect this little power house to be popular amongst HTPC system integrators, DIY enthusiasts and case modders.”
Powered by the AMD E-350 Dual-Core Processor with AMD Radeon™ HD 6310 graphics, the GIGABYTE GA-E350N-USB3 motherboard provides exceptional Blu-ray high definition content playback unmatched by previous integrated graphics solutions. Accompanying the hi-def video out is hi-def 7.1 surround sound audio with S/PDIF out support – another valuable living room PC feature. For connecting and charging portable devices, the GA-E350N-USB3 offers GIGABYTE On/Off Charge technology for quick and convenient charging iPad, iPhone and iPod Touch devices, GIGABYTE 3x USB Power Boost and USB 3.0 from an onboard Renasas (NEC®) controller, ensuring users are able to take advantage the next wave of SuperSpeed USB storage devices.
With regards to build quality, the GA-E350N-USB3 motherboard has been designed to withstand the rigors of an always on device in terms of both energy efficiency and temperature: the GIGABYTE Ultra Durable™ 3 Classic design utilizes 2x the amount of copper of a traditional motherboard PCB, allowing the GA-E350N-USB3 to provide better power efficiency and lower operating temperatures than other designs. Additionally, the GA-E350N-USB3 is equipped with ultra durable all solid Japanese capacitors and GIGABYTE DualBIOS™ technology, which provides a back-up BIOS chip in case the main BIOS becomes corrupted or damaged.
| CPU |
| Chipset |
| Memory |
* Due to Windows 32-bit operating system limitation, when more than 4 GB of physical memory is installed, the actual memory size displayed will be less than 4 GB. |
| Onboard Graphics | Integrated in the APU:
* The DVI-D port does not support D-Sub connector by adapter. * For configuring screen resolution, please refer the user manual- Chapter 1 Hardware Installation of Back Panel Connectors section. |
| Audio |
| LAN |
| Expansion Slots |
| Storage Interface | FCH:
* SATA3 2x performance are maximum theoretical values. Actual performance may vary by system configuration. |
| USB | FCH:
Renasas D720200 chip:
* USB 3.0 10x performance is a maximum theoretical value. Actual performance may vary by system configuration. |
| Internal I/O Connectors |
* This port is mainly used by repair technicians for debugging and problem diagnosis. |
| Back Panel Connectors |
| I/O Controller |
| H/W Monitoring |
| BIOS |
| Unique Features |
* Available functions in EasyTune may differ by motherboard model. |
| Bundle Software |
| Operating System |
| Form Factor |
| Note | * GIGABYTE reserves the right to make any changes to the product specifications and product-related information without prior notice. |
