Mastering Zoom on the Pixel 10 Pro XL: From Optical to Digital
The Google Pixel 10 Pro XL redefines smartphone photography with its intelligent zoom system powered by advanced optics and Google’s AI imaging technology. Whether you’re filming landscapes, cityscapes, or distant details, understanding how the zoom works will help you unlock its full potential.
We were at JB and decided to take a closer look at the Bukit Chagar Station with the DIgital Zoom. (See video below)
1. Adjusting the Zoom Level
You can easily pinch to zoom on the display or use the on-screen zoom slider for fine control. This lets you frame your subject perfectly without missing a moment.
2. Optical Zoom (Up to 5x)
The first 5x zoom on the Pixel 10 Pro XL is powered by optical zoom, using its dedicated telephoto lens to bring subjects closer while preserving true-to-life detail and sharpness. Optical zoom ensures minimal loss in image quality, even when shooting distant objects.
3. Digital Zoom (Beyond 5x, up to 20x)
After 5x, the camera transitions into digital zoom, extending all the way up to 20x. Thanks to Google’s Super Res Zoom technology, every frame is enhanced through AI-driven reconstruction, keeping textures clean and edges crisp even at higher zoom levels.
4. Pro Res Zoom (If Supported)
For those using Pro Res Zoom, this feature automatically kicks in when zooming past optical limits. It uses AI-based stabilization and image enhancement to maintain clarity, reduce shake, and improve overall video sharpness. It’s perfect for handheld recording or capturing motion from afar.
5. Video Recording with Zoom
The Pixel 10 Pro XL supports 4K and 1080p recording across multiple frame rates — 4K at 24/30/60 fps and 1080p at 30/60/120 fps. Zoom functionality remains consistent across all modes, allowing for cinematic, smooth, and stable footage regardless of resolution.
6. Real-World Footage Samples
Below are footages shot using Pro Res Zoom on the Pixel 10 Pro XL, showcasing its ability to capture distant scenes with exceptional clarity, dynamic range, and stabilization — proving just how powerful this feature can be in real-world conditions.
With its seamless transition from optical to digital zoom and smart AI enhancements, the Pixel 10 Pro XL ensures every shot — from wide views to faraway details — looks professional, stable, and remarkably detailed.
The follow video footage is shot with Pixel 10 Pro XL Handheld, no Gimbal is used.
