Kingston Digital Ships SDHC Class 10 Card
High Capacity, Fast Card Perfect for Hi-Def Video Capture and Burst Photography
Hsinchu, Taiwan – (March 2, 2010) – Kingston Digital, Inc., the Flash memory affiliate of Kingston Technology Company, Inc., the independent world leader in memory products, today announced the release of SDHC Class 10 card. The Kingston SDHC Class 10 card is available in 16GB and 32GB capacities. The card meets the Class 10 data transfer rate specification but has an enhanced performance of up to 22MB/sec. read and 18MB/sec. write*.
“As viewing and recording in high definition becomes more popular, the Kingston SDHC Class 10 card’s large storage capability allows users to record hours of video on a single card,” said Nathan Su, Flash Memory Sales Director, APAC Region, Kingston. “The Class 10 speed helps photographers optimize their equipment when it comes to shooting in burst mode as the memory card keeps up with sequential capture.”
The Kingston SDHC Class 10 card is designed to meet the SD Association Specification 3.00 with a guaranteed minimum data transfer rate of 10MB/sec. It is the ideal solution for the latest camcorders, digital SLRs and advanced point and shoot cameras. For compatibility, Kingston recommends users look up their device with the Kingston Memory Search tool on the homepage at www.kingston.com/asia.
The 16GB Kingston SDHC Class 10 card (Kingston part#: SD10/16GB) and the 32GB card (Kingston part#: SD10/32GB) are all backed by a lifetime warranty, free tech support and legendary Kingston reliability.
Kingston SDHC Class 10 Features and Specifications:
·       Capacities**: 16GB. 32GB
·       Dimensions: 0.94″ x 1.25″ x 0.08″ (24mm x 32mm x 2.1mm)
·       Weight: 0.09oz. (2.9g)
·       Performance: Class 10 – 10MB/sec. guaranteed minimum data transfer rate with up to 22MB/sec. read and 18MB/sec. write*
·       Operating Temperature: -13°F to 185°F (-25°C to 85°C)
·       Storage Temperature: -40°F to 185°F (-40°C to 85°C)
·       Voltage: 3.3V
·       Compliant: with the SD Association specification version 3.00
·       Secure: built-in write-protect switch prevents accidental data loss
·       Compatible: with SDHC host devices; not compatible with standard SD-enabled devices/readers
·       File Format: FAT32
·       Reliable: lifetime warranty
·       Simple: as easy as plug and play
Kingston SDHC Class 10 Card
Part Number Capacity and Features
SD10/16GB 16GB Class 10 SDHC Card
SD10/32GB 32GB Class 10 SDHC Card
SDHC Card Capacity Photo1 Video2
6MP Images 8MP Images 10MP Images 12MP Images 6Mbps HD Extended 9Mbps HD Extended 13Mbps HD Extended
16GB 7624 5080 3208 2708 361 min. 240 min. 166 min.
32GB 15248 10160 6416 5416 542 min. 362 min. 251 min.
(MP=Megapixels: MB=Megabytes, GB = Gigabytes)
* Based on internal testing. Performance may vary based on system settings.
** Some of the listed capacity is used for formatting and other functions and thus is not available for data storage.  For more information, please consult Kingston’s Flash Memory Guide at Kingston.com/Flash_Memory_Guide.
1 Approximate number of JPEG (compressed file) pictures. JPEG file sizes vary based upon camera model and internal file size and compression settings, as well as user-selected resolution and compression mode settings. In addition, JPEG compression will result in different file sizes based upon picture complexity. Some host devices may not support all of the Flash storage capacities listed. Consult your device’s owner’s manual for supported capacities.
2 Actual recording time will vary based upon camera model, selected resolution, compression settings and the content being recorded. Some host devices may not support all of the Flash storage capacities listed. Consult your device’s owner’s manual for supported capacities.
