The 960GB SSDNow V310 is a true replacement for HDDs, allowing for the migration of an entire HDD library including music, movies, games, applications and OS onto a single SSD for your Windows PC or Mac. SSDs have no moving pats, are 10x faster than a standard 7200RPM hard drive and allow for up to 77% faster boot up times. At nearly 1TB, it is our largest capacity SSD to date. V310 is easy to install, more reliable and more durable than traditional hard drives.
Buy Now
Hsinchu, Taiwan – July 22, 2014 –Kingston, the independent world leader in memory products, today announced its latest addition to the SSDNow V300 series, the V310. The Kingston® SSDNow V310 solid-state drive dramatically boosts system responsiveness while also offering 960GB capacity to store all movies, music, games, files and applications.
The new SSDNow V310 is 10x faster than a 7200RPM hard-disk drive1 as a result of the Phison 3108 controller and 450MB/s read and write speeds2. With no moving mechanical parts, SSDNow V310 is shock-proof, uses less energy and stays cool making it more reliable and less likely to fail than standard hard-disk drives. The large capacity of the SSDNow V310 allows enough space for a true HDD replacement so users can migrate their entire hard drive over with storage to spare.
“Since 2009, our V ‘Value’ series solid-state drives have delivered the best price to performance ratio as possible to enable consumers on a budget or entry-level users to experience the benefits of SSD technology. Our new V310 continues that along with providing the biggest capacity ever in a Kingston SSD,” said Nathan Su, Flash Memory Sales Director, APAC Region, Kingston. “SSDNow V310 with its large 960GB capacity is the perfect upgrade to an existing system as it improves boot speeds and application load times helping maximize one’s computer investment.”
SSDNow V310 is available in 960GB as a stand-alone drive or as all-in-one kits that include all the accessories needed plus software to clone files and OS to make for an easy install. SSDNow V310 is backed by a three-year warranty, free technical support and legendary Kingston reliability.
Kingston SSDNow V310 Features and Specifications:
  • Faster: improves speed of loading applications and system boot up
  • Reliable: with no moving parts, solid-state drives are less likely to fail than standard hard drives
  • Convenient: all-in-one kits with all the components for easy installation
  • Large capacity: enough space to migrate your entire HDD over to a SSD
  • Form factor: 2.5-inch drive available in 7.0mm with adapter to fit in 9.5mm systems
  • Silent: runs silent and cool
  • Interface: SATA Rev. 3.0 (6Gb/s) – with backwards compatibility to SATA Rev. 2.0
  • Capacities3: 960GB
  • Baseline Performance4:
o   Compressible Data Transfer (ATTO)
  • 450MB/s Read and 450MB/s Write
o   Incompressible Data Transfer (AS-SSD and CrystalDiskMark)
  • 500MB/s Read and 440MB/s Write
o   IOMETER Maximum Random 4k Read/Write
  • 40,000 IOPS and 20,000 IOPS
o   Random 4k Read/Write
  • 27,000 IOPS and 10,500 IOPS
o   PCMARK® 8 Storage Bandwidth Score
  • 4,700
  • Power Consumption: 0.08 W Idle / 1.28 W Avg/ 1.16 W (MAX) Read / 5.39 W (MAX) Write
  • Storage temperature: -40°F to 185°F (-40°C to 85°C)
  • Operating temperature: 32°F to 158°F (0°C to 70°C)
  • Dimensions : 69.8mm x 100.1mm x 7mm
  • Weight: 92.5g
  • Vibration operating: 2.17G Peak (7–800Hz)
  • Vibration non-operating: 20G Peak (10–2000Hz)
  • Life expectancy: 1 million hours MTBF
  • Warranty/support: 3-year warranty with free technical support
  • Total Bytes Written (TBW)62,728TB 2.56DWPD8
Package Contents
Desktop Upgrade Kit
– 3.5″ bracket & mounting screws
– SATA data & power cables
– Hard drive cloning software (CD)5
– Installation video (DVD)
Notebook Upgrade Kit
– 2.5″ USB enclosure
– 7mm to 9.5mm adapter
Desktop/Notebook Upgrade Kit
Part Number Capacity and Features
SV310S37A/960G SSDNow V310 Stand-Alone Drive
SV310S3D7/960G SSDNow V310 Desktop Upgrade Kit7
SV310S3N7A/960G SSDNow V310 Notebook Upgrade Kit7
SV310S3B7A/960G SSDNow V310 Desktop/Notebook Upgrade Kit
Source: PCMark Vantage
Source: ATTO (Compressible Data Transfer)
3 Some of the listed capacity on a Flash storage device is used for formatting and other functions and thus is not available for data storage. As such, the actual available capacity for data storage is less than what is listed on the products. For more information, go to Kingston’s Flash memory Guide at kingston.com/flashguide.
4 Based on “out-of-box performance” using a SATA Rev. 3.0 motherboard. Speed may vary due to host hardware, software, and usage.
Operating system software support: Windows® 7 (SP1), Windows Vista® (SP2), Windows XP (SP3)
Total Bytes Written (TBW) refers to how much total data can be written to an SSD for a given workload before the drive reaches its endurance limits.
Not available in all countries.
8 Drive Writes Per Day (DWPD).
