Before Computex Taipei 2018 begins, we have heard some rumours that manufacturers might be showing the B450 motherboards at the show.
Well, it looks like our guess is right. A leak photo of the MSI B450 has appeared on the net. The B450, which should follow the AMD tradition have similar features like the B350 but  add on for support of faster DRAM, and possibly StoreMI. The B450 is not going to support multi-GPU, it will also support a lower amount of USB 3.1 Gen 1 as well as SATA ports compared to the X470/X370.
In fact, the X470 and X370 has very minor differences and was just an enhancement over the previous generation.
MSI B450 TOMAHAWK appeared at Computex Taipei 2018
