Intro
Contents
The Oppo Find N2 Flip is a sleek and slim clamshell pocket-sized smartphone that boasts impressive dimensions, making it one of the slimmest foldable phones on the market. With an expanded height of approximately 166.2mm and a folded height of around 85.5mm, as well as a width of about 75.2mm in both the expanded and folded states, the device measures only about 7.45mm when expanded and 16.02mm when folded. The phone weighs in at approximately 191g.
Based on the MediaTek Dimensity 9000+, the Oppo Find N2 Flip features a lighter hinge that is easy to use, and a nearly invisible crease. The industry-leading waterdrop hinge is crafted from aircraft-grade high-strength steel and polymer, making it strong and slim, with a seamless folding experience and an immersive screen that keeps you in flow when unfolded.
The main display is a 6.8-inch full HD+ foldable display with a 120Hz refresh rate that also has an exterior display. The 3.26″ cover screen is powered by widgets that allow you to access some common functionalities of the phone without opening the clamshell. With the ability to reply to WhatsApp with emojis without opening the clamshell, you can choose an interactive digital pet from 5 different animals to play with during quiet moments.
The Oppo Find N2 Flip also boasts an impressive camera system. The rear camera features a 50MP wide-angle camera with a Sony IMX890 sensor, 1/1.56” sensor size, f/1.8 aperture, DOL-HDR, and all-pixel omni-directional PDAF. The ultrawide camera is 8MP with a Sony IMX355, 16mm, f/2.2, and 112° ultra-wide camera. The front camera is a 32MP camera with a Sony IMX709 sensor and OPPO’s New Generation RGBW and DOL-HDR. The co-developed camera system gives you the authentic feel of the classic Hasselblad camera, from the iconic leaf shutter sound to the legendary XPan, plus Hasselblad natural colour calibration. Master Filters add even more style to your photography.
The Oppo Find N2 Flip has an all-day battery life and a 44W SUPERVOOC flash charge that charges 50% of the 4300 mAh battery in just 23 minutes. It supports 5G SA/NSA with 2 SIM slots, and e-SIM is supported and activated through scanning a QR code from the operator, which will disable the physical SIM on the phone. The phone supports various bands, including GSM: 850/900/1800/1900MHz, WCDMA: Bands 1/2/4/5/6/8/19, LTE FDD: Bands 1/2/3/4/5/7/8/12/17/18/19/20/25/26/28/32/66, LTE TDD: Bands 38/39/40/41, and 5G NR: n1/n2/n3/n5/n7/n8/n12/n20/n25/n28/n38/n40/n41/n66/n77/n78/n79. (Please note that eSIM support depends on carriers.) Overall, the Oppo Find N2 Flip is an impressive smartphone with advanced features and a sleek design.
