Featuring a 12.4 mm titanised diaphragm driver, wide sound fields, potent bass, crystal-clear vocals, and active noise cancellation (ANC), the earbuds are built to deliver a live concert-like experience. The powerful earbuds come in a snazzy, refractive bubble case, ready to be at the centre of attention anytime.
12.4 mm titanised diaphragm driver + ANC: Your Personal Live Concert
Be it gaming, streaming shows, or listening to your favourite playlist, connoisseurs know that quality audio isn’t just about having a booming bass. It’s about having a clean, well-rounded mid and treble sound too.
The OPPO Enco Air2 Pro is built with a 12.4 mm titanised diaphragm driver, a custom-made large rear chamber, and Enco Live — bass tuning that produces deeper, stronger, and fiercer bass audio, making it perfect for playing deep, heavy beats. Yet, the OPPO Enco Air2 Pro isn’t just made for blasting bass. It is also built to deliver clean, clearly layered vocals for users of the OPPO Enco Air2 Pro to enjoy a refined listening experience be it pop, rock, or instrumental music.
The OPPO Enco Air2 Pro also comes with ANC, which can capture and cancel ambient noise at various frequencies. The power of ANC allows users to listen to their favourite songs without bring distracted by traffic or pedestrian noise. The earbuds also feature a dual mic + AI noise cancellation algorithm setup that will provide users with clear voice calls. Additionally, the OPPO Enco Air2 Pro also supports Transparency Mode so that users can still hear their environment and stay alert without having to take off the earbuds.
Chic and Distinct: Refractive Bubble Case
Adopting a dual-layer, transparent bubble design, the refractive top cover adds a unique touch of translucent lightness. With a design that sets it apart from other earbuds, the OPPO Enco Air2 Pro is set to capture the spotlight.
The OPPO Enco Air2 Pro’s ergonomics have also been further improved with a brand-new smiling curve design. Not only will the charging case look like it is smiling each time it is opened, the special design also allows 77% of the earbuds to be seen instead of the traditional 50%, making it much easier to take the earbuds out. The earbuds themselves also adopt a streamlined design to maximise wear comfort and minimise longtime wear fatigue. Coupled with an IP54 dust and water resistance rating, users are free to bring these earbuds with them to the gym.
28-Hour Super Long Battery: Non-stop Listening
Besides audio performance and design, the OPPO Enco Air2 Pro also excels in other essential areas, including battery life, latency, and user-friendly controls.
The OPPO Enco Air2 Pro can last up to seven hours without its charging case and can stream audio for up to 28 hours with the charging case. It also supports OPPO Flash Charging, where 10 minutes of charging can power two hours of playback time — the perfect amount for a day’s worth of music.
As for connectivity, the OPPO Enco Air2 Pro uses the binaural Bluetooth 5.2 low-latency transmission solution to ensure that users can enjoy industry-leading continuous playback. The earbuds will also automatically enter low latency mode when users are gaming. This feature can provide users with end-to-end latency as low as 94 milliseconds, effectively minimising the chances of unsynchronised audiovisuals and lost connectivity. The OPPO Enco Air2 Pro also comes with smart touch controls such as double tapping, enabling the earbuds to snap a picture and bringing wireless possibilities to a new level.
