Intro
Oppo Reno 10X Zoom Review
20 Aug 2019
Smartphones are now becoming more of a all in one device. Major brands have been enhacing the features of their phones with newer releases almost every alternate month.
This year, we see the trend moving high megapixel smartphones appearing across the mid and high end smart phones. Interestingly, these smartphones have emphasied on it’s capability of doing powerful digital zoom.
Oppo Reno 10X zoom features a 48MP ultra-clear main camera, 13MP telephoto lens and 8MP wide-angle lens make up the Reno 10x Zoom tri-lens setup. By combining three lenses over different focal ranges, this achieves a full bandwidth of 16-160mm, an effective focal length 10 times that of an ultra wide-angle lens. The tri-camera setup complemented by dual OIS for ensuring stability even when fully zoomed on hand-held operation.
In addtional to the camera feautres, the 6.6″ smartphone is powered by Snapdragon 855 for a snappy experience. It run Android 9 with ColorOS 6 and comes with 8 GB RAM and 256 GB of storage. It also has a huge battery capacity of 4065mAh.
Other specifications
Rear Sensor : 48MP + 8MP + 13MP
Front Sensor : 16-megapixel
Aperture :
Front: 16MP F2.0
Rear: 48MP F1.7 + 8MP F2.2 + 13MP F3.0
Features :
Rear 6P camera of 48MP, PDAF, dual OIS;
Front 5P camera of 16MP with beauty function
Camera Mode :
Photo, Video, Expert, Time-lapse, Pano, Night, and Portrait
Other Features : 10x Telephoto
Video :
Front camera: 1080P/720P@30fps
Rear camera: 4K@60fps/30fps, 1080P@60fps/30fps, 720P@60fps/30fps
Frequencies :
【Other contries】 GSM: 850/900/1800/1900MHz
WCDMA: Bands 1/2/4/5/6/8/19
LTE FDD: Bands 1/2/3/4/5/7/8/12/13/17/18/19/20/25/26/28/29/32/66
LTE TDD: Bands 34/38/39/40/41
SIM Card Type : Nano+Nano/Micro SD, 2 of 3
Bluetooth : 5.0
WLAN Function : WLAN 2.4G / WLAN 5G, WLAN Display
OTG : Supported
NFC : Supported
Oppo Reno 10X zoom is one of the two phones that challengers the impossible with a Digital zoom of up to 60X. While other brands feature it capable of taking a clean cut moon photo which leads to controversial, will the Oppo Reno 10X zoom be able to do the same ?
