The Oppo Reno standard version, in both Ocean Green and Jet Black colours, will be available in-stores and Online on 27 April 2019 and will be retailing at S$849 (incl. GST), and the Reno 10x Zoom, also in both Ocean Green and Jet Black , will be available in June 2019, and retailing at S$1,199 (incl. GST). It will bee available in all Singtel, M1, and Starhub.
Specs of Reno 10X Zoom
Height : 16.2cm / 162.0mm
Width : 7.72cm / 77.2mm
Thickness : 0.93cm / 9.3mm
Weight : About 215g
Touchscreen : Multi-touch, Capacitive Screen
Resolution : 2340 by 1080 pixels at 387 ppi
Colors : 16.7 million colors
Screen Ratio : 93.1%
Type : AMOLED on-cell
Rear Sensor : 48MP + 8MP + 13MP
Front Sensor : 16-megapixel
Aperture :
Front: 16MP F2.0
Rear: 48MP F1.7 + 8MP F2.2 + 13MP F3.0
Features :
Rear 6P camera of 48MP, PDAF, dual OIS;
Front 5P camera of 16MP with beauty function
Camera Mode :
Photo, Video, Expert, Time-lapse, Pano, Night, and Portrait
Other Features : 10x telephoto
Video :
Front camera: 1080P/720P@30fps
Rear camera: 4K@60fps/30fps, 1080P@60fps/30fps, 720P@60fps/30fps
Frequencies :
【Other contries】 GSM: 850/900/1800/1900MHz
WCDMA: Bands 1/2/4/5/6/8/19
LTE FDD: Bands 1/2/3/4/5/7/8/12/13/17/18/19/20/25/26/28/29/32/66
LTE TDD: Bands 34/38/39/40/41
SIM Card Type : Nano+Nano/Micro SD, 2 of 3
Bluetooth : 5.0
WLAN Function : WLAN 2.4G / WLAN 5G, WLAN Display
OTG : Supported
NFC : Supported
Specs of Reno
Height : 15.66cm / 156.6mm
Width : 7.43cm / 74.3mm
Thickness : 0.90cm / 9.0mm
Weight : About 185g
Resolution : 2340 by 1080 pixels at 402 ppi
Rear Sensor : 48MP & 5MP
Aperture :
Front: 16MP F2.0
Rear: 48MP F1.7 + 5MP F2.4
Features :
Rear 6P camera of 48MP, PDAF;
Camera Mode :
Photo, Video, Expert, Pano, Portrait, Night, Time Lapse, and Slo-Mo
Video :
Rear camera: Up to 4K@30fps, 1080P@60fps/30fps, 720P@60fps/30fps
Frequencies :
WCDMA: Bands 1/2/4/5/8
LTE FDD: Bands 1/2/3/4/5/7/8/20/28
LTE TDD: Bands 38/39/40/41
SIM Card Type : Nano-SIM / Nano-USIM
Bluetooth : 5.0
OTG : Supported
NFC : Supported
[nextpage title=”Press Release”]
OPPO Singapore today announced the launch of their new Reno
series of phones, set to inspire a new generation of innovative creators. The launch comes off the back of the brand’s recent ‘Imagine, A Step Closer’ press launch in Shanghai earlier this month.
Consisting of the standard edition Reno and the Reno 10x Zoom, models in the new range are fitted with panoramic display panels and showcase integrated, flawless bodies. With its 10 times hybrid zoom, the Reno 10x Zoom kicks off the company’s creative vision to inspire Singaporeans to find new ways to express their creativity.
The Reno series features a full frontal panoramic front display – the Reno standard version packs a 6.4-inch OLED display and the Reno 10x Zoom, a 6.6-inch OLED display. The bezel of the Reno series measures a mere 3.5mm, resulting in impressive screen ratio of up to 93.1% for even greater visual enjoyment. It also comes with the latest luminescent material, which spans the entire DCI-P3 colour spectrum. Besides allowing the display to be clearer and more vibrant, the device is also rendered more power-efficient. Reno is equipped with sixth generation Corning® Gorilla glass further increases the durability of this display.
To create a seamless back with no bulges, OPPO has placed the phone’s rear camera completely under a single piece of glass. The wide curvature of the 3D glass panels on each of its four sides makes the phone fit nicely in one’s hand.
Having adopted a brand-new condensation grading process which produces a more layered, three-dimensional gradient effect, the Reno series is more aesthetically pleasing than ever. In addition, its Ocean Green model makes use of a localised AG fog surface etching process to achieve double texture on its glass panels – an industry first.
It is OPPO’s creative focus that has allowed the Reno series to achieve such an integrated and flawless exterior design. Within the Reno, this comes in the form of an innovative side rotation elevation design allowing the brand to conceal the front camera, soft light, back flash within the device. The entire mechanism requires just 0.8 seconds for the camera to appear and the smoothness of its functionality creates not the slightest sound even in the quietest of nights.
The Reno also comes equipped with a new generation light-sensitive fingerprint system. A new lighting system and algorithm improves fingerprint-unlocking success rate by 20 – 30%, and improves unlocking speeds by 28.5%.
10x hybrid zoom, furthering your vision
OPPO has always been known to place the highest priority on its camera. This comes through even more so with the Reno which is fitted with Sony’s 48MP IMX586 sensors for outstanding night scene photography.
Furthermore, with its all-new upgraded Ultra Night Mode 2.0, it elevates the clarity and brightness of images through composite multi-frame noise reduction and multi-frame HDR technology. The Reno 10x Zoom greatly reduces the processing time required for night scene photography to just 2 or 3 seconds. The combined utilisation of both hardware and software
allows the Reno to capture real, bright colours and night scene photographs with distinct
gradation and texture.
The Reno 10x Zoom also boasts 10 times hybrid zoom technology. It does so through a combination of three different zoom lenses: The 48MP super definition main camera lens, 13MP telephoto camera lens and the 8MP 120° wide-angle camera lens. This provides users with a whole new range of possibilities when it comes to picture compositions by providing effective focal lengths that range from super wide-angle, telephoto lens to the commonly used 16mm – 160mm focal lengths.
The Reno 10x Zoom times zoom version allows more possibility to picture composition To fit the telephoto lens in this light-frame device, the OPPO Reno 10x Zoom incorporated three major innovations – first, the horizontal arrangement of the periscope telephoto lens, second, the reduction of the lens thickness with D-Cut technology, and last, its common motor design
that allows two originally independent components, the main lens and wide-angle lens, to be combined into one thus reducing the required interior space.
The entire combination of the telephoto lens and periscope mode measures only 5.75mm in thickness, facilitating the possibility of both the high zoom and light device frame. To ensure the quality of long zoom photography, the Reno 10x Zoom makes use of a dual OIS optical anti-shake design in its main camera lens and telephoto lens to effectively mitigate the impact of device vibration, allowing for clearer photographs.
Imaging has always been OPPO’s core strategy. In addition to hardware and algorithms, OPPO always strives to help users find new ways of expressing. As such, it is always working to and simplify the process of taking good photographs.
With this in mind, OPPO is set to work with Magnum in its OPPO x magnum creative imaging plans to create a professional interaction platform where mobile device users and photography
enthusiasts worldwide can come together to display their talent and creativity.
Hardware and Software That Offers Full Immersion In The Gaming Experience OPPO has never slowed its pace in elevating the gaming experience for users. With the Reno series, OPPO aims to allow users full immersion in their gaming experience.
In terms of hardware, the Reno 10x Zoom incorporates the Qualcomm Snapdragon 855 mobile platform and contains the greatest 8GB + 256 GB storage combination. It is intended for the newly upgraded processor platform and improved storage space to fulfil the requirements of
the most massive of games. In addition, the Reno 10x Zoom version is equipped with lateral
linear motor, copper tube liquid cooling, stereo speakers, three microphones stereo sound pick- up and other hardware accessories that elevate the gaming experience for users through the
finest details. The Reno standard version, on the other hand, is equipped with Qualcomm Snapdragon 710 mobile platform with storage combination of 8GB + 256GB and 3765mAh battery and VOOC 3.0.
In terms of software, the Reno series is equipped with the brand new elevated GameBoost 2.0 that comes with the brand-new Frame Boost and Touch Boost functionalities. The former allocatessystem resources according to the game’s requirements of system resources in a timely
manner while the latter is able to greatly increase the reactivity speed of the touch screen, bringing users an improved gaming experience through a “faster scoping, accurate ultimate skill” upgrade.
