In less than 30 minutes, Xiaomi will launch the POCO X3. The launch event will be held live on the internet. You can view the live stream below.
What should we be expecting from POCO X3 ?
According to online leaks, the Poco X3 NFC will sport a 5,160mAh battery that supports 33W fast charging, as per an alleged protective sleeve. The 6.67-inch full-HD+ display supports a 120Hz refresh rate and a 240Hz touch sampling rate. The device will be powered by Snapdragon 732G SoC. It also notes a quad rear camera setup with a 64-megapixel primary sensor, a 20-megapixel camera for selfies. From the specs, it looks like it is a 4G smartphone with no 5G support.
The Poco X3 NFC is probably come with 6GB RAM onboard, and 64GB of inbuilt storage. It was spotted running MIUI in an unboxing video, and is expected to be running on top of Android 10. The phone has a fingerprint scanner on the side of the device that doubles up as a power button.
