REDMAGIC, a global leader in gaming technology, today unveils the REDMAGIC 11 Air, the latest evolution in its Air series gaming smartphones. Combining an ultra-slim design with flagship-level performance, advanced cooling, and all-day endurance, the 11 Air sets a new benchmark for what a lightweight gaming device can achieve. Powered by the Qualcomm Snapdragon 8 Elite, the RedCore R4 gaming chip, a 7,000mAh battery, and next-generation active cooling, the 11 Air delivers seamless gameplay, vivid visuals, and intelligent AI-driven enhancements for both gaming and everyday use.
Flagship-Level Performance and Advanced Gaming Optimization
Powered by the Snapdragon 8 Elite and paired with up to 16GB of RAM and 512GB of storage, the 11 Air delivers exceptional speed, efficiency, and multitasking capability. Compared with the Snapdragon 8 Gen 3 found in the 10 Air, the new platform enables smoother gameplay, faster  load times, and more consistent performance under demanding workloads.
Complementing the SoC, REDMAGIC integrates its proprietary CUBE system-level scheduling engine with the RedCore R4 gaming chip, a dedicated processor optimized for gaming, to deliver advanced performance enhancements:
  • Super Resolution & Frame Rate: Upscales 60fps games to 144fps, enhancing visual clarity and ensuring ultra-smooth motion.
  • Image Rendering: Improves color, contrast, and detail, supporting stylized filters for a cinematic gaming experience.
  • Haptics Optimization: Works with the device’s linear motor to deliver immersive 4D vibrations, responding to in-game cues such as footsteps and gunfire.
  • Audio & Lighting Control: Synchronizes RGB lighting with in-game audio, creating a fully immersive esports environment.
Beyond feature enhancements, the system refines four core performance dimensions. The SoC is designed to minimize frequency throttling and maintain display brightness stability, supporting more consistent high-level performance during extended use. Intelligent load prediction maintains stable frame rates, minimizing drops during intense gameplay, while power consumption is optimized during less demanding scenes to extend battery life. At the same time, visual fidelity remains consistently high, with sharp details and vibrant color reproduction preserved even during extended gaming sessions—delivering a smoother, more responsive  experience that clearly advances beyond the 10 Air.
Ultra-Thin Design That Redefines Lightweight Gaming
The REDMAGIC 11 Air is the slimmest and lightest smartphone in the REDMAGIC Air series, measuring 12% thinner and 10% lighter than the 11 Pro, while maintaining a comfortable, ergonomic grip for extended gaming sessions. Its next-generation industrial design blends subtle curves with a transparent gaming aesthetic and immersive RGB lighting, resulting in a distinctive, instantly signature look. Despite fully upgraded internal hardware, the 11 Air retains the slim profile of the 10 Air, demonstrating that high-performance gaming no longer requires sacrificing portability or elegance.
Active Cooling Breakthrough in an Ultra-Slim Form Factor
The REDMAGIC 11 Air redefines thermal management in slim-form-factor smartphones by introducing active cooling within a compact, lightweight chassis:
  • First in Air Series – Turbo Cooling Fan: Building on the engineering breakthroughs of the 10 Air, the 11 Air features the first active cooling turbofan in the Air series. The compact yet powerful 24,000 RPM fan, with staggered high and low fins, maximizes airflow and  efficiently dissipates heat, ensuring stable and consistent performance even during prolonged, high-intensity gaming sessions.
  • Patented 4D Ice-Steps Vapor Chamber: The upgraded ultra-thick vapor chamber delivers a 40% improvement in heat diffusion efficiency, enabled by a 40% larger vapor space. Its unique “ Ice-Steps” tiered structure expands the surface area by utilizing irregular internal cavities, creating larger steam channels that accelerate heat dispersion and minimize hotspot formation. This advanced design results in cooler device temperatures and sustained performance under heavy load.
This upgraded ICE cooling system guarantees that the 11 Air remains cool, responsive, and reliable throughout extended gameplay, all while maintaining its ultra-thin form factor. Compared to the 10 Air, this next-generation cooling system represents a significant leap in both thermal efficiency and sustained performance, proving that lightweight design no longer requires compromising on flagship-level cooling.
Flagship-Level Endurance with Smart Charge Separation
Despite its slim and lightweight design, the REDMAGIC 11 Air houses a high-capacity 7,000mAh battery, delivering flagship-level endurance. This marks a 1,000mAh increase over the 10 Air, supporting longer gaming sessions, extended streaming, and reliable daily use, with rapid top-ups via 80W fast charging.
REDMAGIC’s exclusive Charge Separation technology allows power to be supplied directly to the motherboard during gaming while bypassing the battery, significantly reducing heat generation and helping preserve long-term battery health. Paired with PowerCube AI Energy Management, the system intelligently balances performance and efficiency to maximize runtime and ensure consistent, uninterrupted use across a wide range of scenarios.
Immersive Visuals, Audio, and Precision Controls
The 11 Air features a high-resolution 2688×1216 full-screen display with ultra-narrow bezels and a 144Hz refresh rate, offering smoother, more responsive visuals compared to the 120Hz panel on the 10 Air. Dual high-performance stereo speakers (1012 + 1115K) deliver richer, more balanced audio, while the upgraded 0809 X-axis linear motor provides precise, directional haptic feedback. IP54 dust and water resistance further enhances durability and reliability.
Exclusive 520Hz shoulder triggers deliver console-style precision, while vertical gaming support expands gameplay possibilities. Working in tandem with the RedCore R4 chip, these controls offer ultra-responsive, low-latency input, giving competitive gamers a clear tactical advantage  over the previous generation.
AI-Driven Gaming Intelligence and Everyday Productivity
Game Space introduces a robust suite of AI-driven features designed to enhance both gaming performance and everyday productivity:
Tactical Coach: Offers real-time tactical guidance for MLBB, Free Fire, and PUBG MOBILE.
  • Mora Mouthpiece & Voice Control: Automatically generates in-game communication and maps voice commands to actions, enabling hands-free gameplay.
  • AI Smart Input: Industry-leading, context-aware text generation for fast and accurate messaging.
  • Mora App Upgrade: Interactive companion with new skins, startup animations, and daily chat features for more lifelike engagement.
  • Multi-Screen Collaboration: Enables the phone to serve as a second screen for tablets or PCs, mirroring notifications and extending productivity.
  • Vertical Gaming Trigger Support: Expands gameplay dimensions by enabling dual shoulder buttons in vertical-oriented games.
These AI-powered tools, combined with the upgraded hardware and software, deliver smarter, more immersive experiences, setting the 11 Air apart from the 10 Air in both capability and versatility.
Advanced Imaging, Connectivity, and Smart Daily Features
The REDMAGIC 11 Air delivers AI-enhanced imaging with a 50MP main camera (OIS), 8MP ultra-wide lens, and a 16MP front camera, producing sharp, detailed photos even in low-light conditions. Connectivity options include 5G, Wi-Fi 6, NFC, and infrared smart control.
Integration with Google Gemini AI enables real-time translation, AI-assisted input, and smart device management. Combined with the REDMAGIC 11.0 software system, the 11 Air offers smooth performance, reliability, and productivity that extend well beyond gaming.
Pricing and Availability
ProductVariantsPromo PriceAvailability
REDMAGIC 11 AirPhantom / Prism(12+256GB)SGD779
Available from 1 Feb 2026, 8pm on Shopee REDMAGIC Official Store, Lazada Flagship Store, and TikTok REDMAGIC Singapore.
Phantom / Prism(16+512GB)  SGD919
