After years of waiting, M1 Maxx has finally enabled access to the 5G Standalone network.
With free 5G access in Singapore, Malaysia, and Indonesia, you can enjoy next-level speeds wherever 5G coverage is available. Whether you’re at home or traveling, you can count on faster download and upload speeds that far exceed what 4G can deliver.
5G Speed
We’ve conducted speed tests in various malls and HDB estates across Singapore, and the results are impressive. Connected to n78 band or n78+n1 band, on average, speeds ranged from 400 Mbps to 800 Mbps, which is already a significant leap forward compared to 4G speeds. The latency is also way lower into sub 20ms and can be as low as 16 ms.
When inside shopping malls, the downlink speeds could hit a remarkable 1.2 Gbps, and the uplink speeds could reach 125 Mbps perfect for smooth streaming, downloading or uploading no matter where you are.
The 5G SA network ensures lower latency and higher reliability, meaning less lag and faster connections, which are key for tasks like gaming, streaming high-quality videos, or video conferencing mainly due to lower latency and higher bandwidth. In fact, to stream a 4K video, you do not even need 1 Gbps of bandwidth on the go.
Although most of the places I visited I am able to get 5G (SA) coverage, some locations like shopping malls or MRT stations will get you connected to their 5G(NSA) which usually anchors Band b3 and Band n1. It still gives you pretty good speed as compared to 4G+. Do take note, there will still be places where 5G is not available and data connection will fall back to 4G or 4G+.
Data Roaming in neighbouring countries
Shared Data Roam Across Multiple Countries 500GB! One of the standout features of this plan is the 500GB of shared data that can be used across Singapore, Malaysia, and Indonesia. Whether you re staying local or hopping between these countries, you can seamlessly use your data without worrying about excessive roaming charges. Managing your data usage becomes a breeze when it s shared across these regions.
User submission shows that it is able to get over 300 Mbps at R&F just across the causeway.
20GB of APAC roaming and 7GB of international roaming. Perfect for frequent travelers or anyone who needs to stay connected while abroad. IDD Minutes and International Calling. The down side is that Maxx does not support VoLTE Roaming, effectively you have to use WhatsApp to make voice calls.
For users who have friends and relatives in the region, you can use up to 600 minutes of IDD (International Direct Dial) calls to countries like Malaysia, Bangladesh, India, and China. You also get: 200 minutes to Indonesia. 120 minutes to Myanmar. 50 minutes to the Philippines.
Local Features Calls, SMS, and More The M1 Maxx $12 Plan covers all your local calling and messaging needs too. You get: 500 minutes of local outgoing calls Unlimited local incoming calls 50 local SMS No more worries about running out of talk time for both personal and work calls. Plus, with Caller Number Display included for free, you ll always know who s calling.
Porting in
Flexibility Port in Your Own Number Another great feature is the ability to get started with a temporary number during sign-up. Once you re ready, you can easily port in your own number, ensuring you keep the number you ve had for years no need to switch! It s a seamless process and adds an extra layer of flexibility to the plan.
Auto-Renew Every 30 Days The M1 Maxx $12 Plan is designed for convenience. It auto-renews every 30 days, so you don t need to worry about manually renewing or top-ups. Set it and forget it, and it ll keep on giving you great service without interruption. If you forget, you will fall back to the Base Plan which still enables you to stay connected for the next 60 days with minimum data and call minutes.
Final Thoughts: Is the M1 Maxx $12 Plan Worth It? If you re looking for a budget-friendly plan that doesn’t skimp on features,
The combination of 500GB of shared data for Singapore, Malaysia, and Indonesia, free 5G, IDD minutes, roaming data, and local calling features makes it one of the most competitive and comprehensive plans available. With the recent 5G speed tests showing incredible performance with speeds reaching 1.2 Gbps in malls and up to 800 Mbps in HDB estates this plan is more than just talk.
It’s the real deal for fast, reliable mobile connectivity. Whether you’re a frequent traveler, a business professional, or simply someone who wants fast speeds and excellent coverage across multiple countries, this plan has you covered. The wait for 5G SA is over, and M1 Maxx is making it more than worth your while.
