The package – ASUS ENGTX460 TOP
Bluetooth 20 Jul 2010
The package is pretty straightforward. It comes with 2 D-SUB connectors, a CDROM, a manual and a power cable adaptor.
Below are some screen shots of the product. It looks quite different from the reference card. The 2 power connector  are on the top. The copper heatpipe helps dissipate the heat better than conventional design.
