BIOS Options
Contents
The BIOS has plenty of options for tweaking the machine esp for overclocking. Vcore, Vdimm, Memory settings XMP or manual adjustments can be done. Multiplier ratio and the clock is also available for overclocking use.
If you are new to overclocking or just want to have a stable working system with a slight boost, the Easytune software which you can download and install from Gigabyte website allows you to easily auto tune the system for higher processor clock without compromising stability.
