Intro
Contents
Do you experience slow Wi-Fi on your laptop due to distance from your router? Are you a gamer seeking a stable, low-latency connection?
Price – $79 at Lazada
The Belkin USB-C to 2.5 Gb Ethernet adapter is your solution. This compact, lightweight adapter delivers the reliable, high-speed connection you need for gaming, streaming, and video conferencing. It’s compatible with most laptops, including Chromebooks with a USB-C 3.0 or later port. Simply connect the adapter to your laptop and plug in a Cat 6 cable to your router or switch for a significant boost in speed and stability.
The Belkin Connect USB-C to 2.5 Gb Ethernet Adapter (INC012) Comes with 2 years warranty and works with Windows® 10 and 11
macOS® 10.14 or above
Chrome OS™ 44 or above
It supports the following ports and network speeds:
Thunderbolt™ 3 and Thunderbolt 4 ports
Network speeds of up to 10, 100, 1000, and 2500 Mbps
