Intro
Contents
If you are looking for an affordable 4G phone to replace your aging phone, the Redmi 10 might be worth considering.
Bearing a 6.5″ FHD Dot play at 2400×1080 and up to 90 Hz refresh rate with AdaptiveDisplay, scrolling has become smoother than before. It also comes with Dual speakers and a 3.5mm headphone jack.
Although it is slimer at 8.92mm, it does weigh at 181 grams. That could be due to the 5000mAh battery built in that can be charged up with 18W fast charging. It supports 9W reverse wired charging. A 22.5W charger comes with the package.
Entry level yet it is big on it’s cameras, it has 4 cameras
- 50 MP f/1.8 back camera
- 8 MP f/2.2 back wide angle camera 120 degrees
- 2 MP macro f/2.4 back camera
- 8 MP f/2.0 camera
Although it isn’t paired with a Snapdragon, performance of the Mediatek Helio G88 is comparable Snapdragon 660.
Network & Connectivity
SIM 1 + Hybrid (SIM or MicroSD)
Expandable storage up to 512GB
2G: GSM: 850 900 1800 1900MHz3G: WCDMA:1/2/4/5/8
4G: LTE FDD:1/2/3/4/5/7/20/284G: LTE TDD:38/40/41
Wireless Networks
Bluetooth 5.1
Supports 2.4GHz Wi-Fi/5GHz Wi-Fi
Supports FM radio
