Today SIMBA Telecom introduce a new plan dedicated to the frequent travellers. Known as the SIMBA SuperRoam, it comes with 80 GB of local data, Unlimited calls to local mobile, Unlimited SMS to TPG Mobile, 500 Local calls to local fixed line, 300 minutes IDD to selected countries and 100 local SMS, it comes with a generous 10 GB of Roaming Data at 57 countries/territories. All these at S$25/mth.
Although the plan is impressive, there are something that you need to take note :
VoLTE capable handsets supported by our network are listed here.
Please ensure that data roaming settings are enabled in your handset. While roaming on a VoLTE supported roaming network, you will be able to make and receive calls while roaming. Otherwise, download TPG 4G Voice App to make and receive voice calls.
Currently, TPG 4G Voice App can only be used in 7 destinations: Malaysia, Indonesia, Thailand, Philippines, India, Japan, Taiwan.
SIMBA Super Roam is a cost-effective roaming data product that provides subscribers with seamless data connectivity while roaming.
To remain contactable overseas, download TPG 4G Voice App. Currently, TPG 4G Voice App can only be used in these destinations: Malaysia, Indonesia, Thailand, Philippines, India, Japan, Taiwan. This App allows you:
  • to make calls when you are overseas using your plan entitlements. In addition, you continue to enjoy all the Singapore local perks such as Free incoming calls, Unlimited calls to Singapore telco.
  • to make calls within your overseas destination via TPG All-Day-Low IDD rates. Click here for full IDD rates.
Caller ID, all incoming voice calls and SMS (local and roaming) are free. Outgoing SMS is not supported when roaming.
To be roam ready, please ensure that your TPG SIM is slotted into your mobile device at least 48 hours before departure. This allows your SIM to be updated with the latest parameters. To check if your SIM is roaming ready, SMS <TPG> to 1218.
On device settings, please ensure the following:
  • Data settings: Turn on Data Roaming
  • Network selection: Set to Automatic
  • APN settings: Key in TPG to Name and APN
