Android 10 was officially announced for it’s Pixel series of smartphones earlier this month. If you are an early adopter during the beta 1 to 6, you would have noticed that some apps didn’t work quite well with Android 10.
Although we hope that such apps would have rectified it since Android 10 evolved from beta 1 to 6, apps like Singtel Dash, Citibank still couldn’t work properly on Android 10.
The apps aborted or couldn’t continue without strange issues.
I think there are more apps out there that might be incompatible with Android 10. It is best that you check out the apps information. Check out the comments on app store and ensure that the app works under Android 10 before upgrading.
