Unboxing video of the SONY 256GB USB 3.0 Ext SSD SL-BG2
Features
Ultra Compact
Shock Proof
Fastest read speed of 450MB/S
Anti Scratch
Aluminum Finishing
Long life expectancy
Choose a model
Find a Sony store near you
Support for this product
SPECIFICATIONS
HARD DRIVE
Capacity 256GB
File System NTFS
Dimension (W x H x D) Approx. 37 x 9.4 x 78.2mm (without protrusions)
Weight Approx. 35g
INTERFACE
USB Port USB 3.0/USB 2.0 x1
Port Type USB 3.0 Micro-B connector
Transfer Rate (Max) 5Gbps (USB 3.0), 480Mbps (USB2.0)
OPERATING SYSTEM
Supported Operating System Windows 8.1(32bit/64bit), Windows 8(32bit/64bit), Windows 7(32bit/64bit), Windows Vista(32bit/64bit), Mac OS X 10.8 or later
POWER
Power Supply DC 5V (USB bus powered)
Power Consumption Max. 4.5W
SUPPLIED ACCESSORIES
Operating Instructions Yes
Cable USB 3.0 Standard-A to USB 3.0 Micro-B cable (30cm)
SERVICE AND WARRANTY
Services Support Period 3 years
PC SOFTWARE SYSTEM REQUIREMENTS
Operating System Windows 8.1 (32bit/64bit)[Windows 8.1, Windows 8.1 Pro], Windows 8 (32bit/64bit)[Windows 8, Windows 8 Pro], Windows 7 (32bit/64bit)[Starter, Home Basic, Home Premium, Professional, Enterprise, Ultimate], Windows Vista (32bit/64bit)[Home Basic, Home Premium, Business, Ultimate]
Display High Color (more than 16bit), 800×600 pixels or more
Memory 256MB or more (If OS recommends more, the memory size is required)
CPU Pentium III 450MHz or faster (If OS recommends more, the CPU is required)
