Video shot in 4K
This video was shot in 4K/30 fps with Standard Stablisation turn on (default). It is mounted on the DJI osmo SE gimbal. There is a Ultra Stablisation mode which records only in 1080p/30 or /60 fps. That mode will give you a gimbal like recording. That is useful if you are walking and recording without attaching it to a gimbal
Other than the flickering lights due to the 30 fps recording mode, the video quality is superb. I think the missing 25 fps / 50 fps option should be made available in a manual option offered in the X200FE.
The AI noise eraser comes handy if you want to remove the noise in the video recorded and enhance the voice.
